Squeeeeky blazeR2000gstclips 01-07-2008, 06:38 PM Well before I roll into the dealer and spend 59.99 on a diagnosis I thought I would give wonderful AF a shot. The vehicle is a 2000 Chev Blazer ZR2, with 132,000 miles on it. The Problem: although not a big problem it is annoying and I feel that there might be issues down the road if not taken care of now. When I start the vehicle it squeeks, the sound is coming somewhere near the belt. The belt was replaced by the dealership less than 3,000 miles ago. I drive 45 min to work every morning and when I get to work I can faintly hear the squeeking. could something be leaking on the belt causing this annoyance? Water pump or bad alternator cause a squeezing? All guages are fine and I did just replace the heater core and someone had told me that a bad heater core takes a toll on the water pump but I can't understand why the blaze is squeeking so much :-( any help would be great. THANKS in advance! blazes9395 01-07-2008, 09:35 PM Basiclly take a look under the hood and closely watch and listen for the squeek. Take the belt off and turn each pully and feel/listen for noise/roughness. If its the belt that is squeeking, and it has been recently replaced, then you have to see if a pully is misaligned as a result of worn bearings. Pull and push each pully, make sure they don't have abnormal play in them. That should help you pinpoint the problem. cardboardpimp420 01-07-2008, 10:10 PM one way to locate a squeak w/o taking the belt off is to take a long wrench or a screw driver, press one end against your ear and start touching the parts that the belt drives with the other end. The part that is squeaking will be significantly louder. Automotive Network, Inc., Copyright ©2012
