Re: 1994 jetta engine 2.0
Your starter is in the front of the engine, by the transmission. It is held in by two bolts and has hot wires going to it. You need to disconnect the battery. It is easy to remove, but one of the bolts is part of the front engine mount. It will require you to have a jack to support the weight of the engine while you remove the upper starter mount bolt.
