I have a 1994 Escort with the 1.9L motor. For 3 weeks it has been on and off broke and repaired. I have replaced the fuel pump, fuel filter,the main computer, ignition module (thing by the battery/fuse box under the hood in the engine bay), crank sensor, and fuel pump relay. I got it back from my mechanic yesterday and it was cranking fine, all day. This morning after sitting all night it only turns over. I cannot hear the fuel pump running when I turn on the key. I have tried to bypass the cut-off switch in the trunk (which was not tripped fwiw) and still have no fuel pressure. Any help will be GREATLY appreciated. This is my only ride to work
