Programming Keyless Entry Fobybrady 02-19-2003, 11:39 AM I have a 95 XLT. The batteries in my keyless entry fob died. I did not replace them right away. When I replaced the batteries the remote did not work. I do not want to pay the dealer an arm and a leg for 1 minute of work. Can anyone help me re-program my my fob? Thnx.:) fordman123 03-14-2003, 07:10 PM Make sure that the anti-theft system is not armed or triggered Turn the ignition key from OFF to RUN five times within 10 seconds, ending in RUN. If the RAP system has successfully entered program mode, it will lock and then unlock all doors. Press any button on a transmitter, and the doors will lock and then unlock to confirm that each transmitter has been programmed. If the vehicle has memory seats, look on the back of the transmitters and make sure that transmitter No. 1 is programed first, and that transmitter No. 2 is programmed second. If the door locks do not respond for any transmitter, wait a few seconds and press the button again. If the door locks still fail to respond, go to Pinpoint Test A . Turn ignition OFF (or wait up to five minutes after Step 2) to exit program mode. If a new set of transmitters have been programmed (or reprogrammed), the remote control alarm and door lock system will lock and unlock all doors one last time to confirm. ybrady 03-17-2003, 08:09 AM Thanks a million.:flash: bwick99 05-13-2003, 12:59 AM Thanks, The directions are excellent. took about 5 minutes and the remote worked great. tjavascript:smilie(':)') smilehe TennTom 06-24-2004, 01:47 AM fordman123 or someone else . . . Can you help me program two remotes on my 2002 Explorer? I followed the reprogramming instructions, turning the ignition between lock and on eight times in 10 seconds. The doors locked and unlocked as they were suppose to. The first of two remotes locked the doors, but the second one did not. But neither remote worked when I finished. Now when I try to reprogram again, I get the lock/unlock confirm OK, but absolutely nothing happens when I press either remote. I checked the batteries in both and they test OK. What did I do wrong? Appreciate any help. steve11 06-25-2004, 10:49 PM are you sure the remotes are for a 2002 explorer? there are several different models of the remote and they only work with specific autos. does it look like the original? TennTom 06-26-2004, 12:25 AM steve11 Not at all sure that they are for a 2002. Is there any way to tell by looking inside or outside? XLT03 06-26-2004, 01:02 AM TennTom: Try this link www.remotesunlimited.com for method to identify your remotes. I assume that the remotes you have in your hands came with the car and you were using it before and for some reason need to have them reprogram? Or are they remotes you got and you want to use them also? FYI, you can only have four remotes. If you have the first two and you want to add 2 more, all four must be done at the same time for them to work. The FCC ID on the back of the remotes must all be the same, do not go with the looks only. TennTom 06-26-2004, 01:11 AM XLT03 Thanks for the link. Will give it a look. No, my remotes aren't original equipment. steve11 06-26-2004, 09:01 AM my remote is 1.4 x 1.7 inches , says 2L2T-15K601-BA on the back. top two ROUND buttons are pictures of alock, and un lock. bottom SQUARE pictures are a red horn and blue hatch back. my 98 mustang is 1.4 x 2 inches, four buttons have names, not drawings of the above, "lock, unlock, panic, trunk". SlyPerez 04-19-2008, 03:49 PM fordman123 or someone else . . . Can you help me program two remotes on my 2002 Explorer? I followed the reprogramming instructions, turning the ignition between lock and on eight times in 10 seconds. The doors locked and unlocked as they were suppose to. The first of two remotes locked the doors, but the second one did not. But neither remote worked when I finished. Now when I try to reprogram again, I get the lock/unlock confirm OK, but absolutely nothing happens when I press either remote. I checked the batteries in both and they test OK. What did I do wrong? Appreciate any help. I did exactly the same as you did and I have the same problem. If you find out how to solve it, please let me know, if I find it out first I'll let you know. shorod 04-19-2008, 04:49 PM Do you have an owner's manual for your Explorer? If so, the procedure for your specific vehicle should be listed in the owner's manual. What year is your Explorer? Do you know if the remotes you have ever worked? Since this thread is almost 4 years old now, I wouldn't count on someone responding to a post of theirs from that long ago. -Rod SlyPerez 04-21-2008, 11:53 PM My explorer is 2002... SlyPerez 04-22-2008, 12:03 AM One of them is the one I've been using since I bought my Explorer. My problem started when I got the second one. I followed the reprogramming instructions, turning the ignition between lock and on eight times in 10 seconds. The doors locked and unlocked as they were suppose to. The first of two remotes locked the doors, but the second one did not. But neither remote worked when I finished. Now when I try to reprogram again, I get the lock/unlock confirm OK, but absolutely nothing happens when I press either remote. Exactly the same that happened to "Tenn Tom" shorod 04-22-2008, 08:06 AM Page 121 of the owner's manual explains the process. Sounds like you are doing all the correct steps and getting the correct indications.... Does the FCC ID of the second remote match that of the original remote? Although if not, I'm not sure why the original remote wouldn't work, unless playing with the programming coincidently caused the remote battery to go dead. From the owner's manual (http://www.motorcraftservice.com/pubs/content/%7EWO2EXP/%7EMUS%7ELEN/42/02expog6e.pdf): To program the transmitters yourself: Insert a key in the ignition and turn from 1 (LOCK) to 3 (ON) and cycle between 1 (LOCK) and 3 (ON) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 3 (ON) position. The doors will lock/unlock to confirm that programming mode has been entered. Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.) Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed. When you have completed programming the remote transmitters, turn the ignition to 1 (LOCK) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.-Rod SlyPerez 04-22-2008, 11:46 PM The one I was using in the back says: 1L2T-15K601-AA FCC ID: CWTWB1U322 CAN: 1788 102 354 The one I bought: 2L2T-15K601-BA FCC ID: CWTWB1U331 CAN: 1788 104 575 I did exactly as you said, nothing happened. shorod 04-23-2008, 08:19 AM A couple of sites I looked at imply that those two remotes are no necessarily compatible. I'm not sure if/why that would prevent you from being able to program the original one that used to work. Have you tried programming each one separately to see if they both work individually? Go through the process but only program the remote that you know used to work. If that works fine, then go through the process for the "new" remote and see if it works. If the original will program and work, but the new one will not, then you probably can decide the new one is not compatible and reprogram just the original again. FWIW, it appears the first digits of the Ford part number are most significant. I checked three remotes I have sitting around here and the first 4 digits are the only ones that are different. 1998 Taurus SHO -> 2S4T-15K601-AA 2000 Mountaineer -> F8DB... 2002 Lincoln LS -> 2S4T... -Rod billabongblue03 07-02-2008, 12:32 AM Hey SlyPerez I have been currrently having the exact same problem with programing my keyless remotes with the exact same car and exact same two remote codes. I have tried entering or program mode various time and nothing occurs when I press the button on the remotes. did you ever fix or resolve this problem Automotive Network, Inc., Copyright ©2012
