1991 Deville won't start
Melitta
01-05-2008, 03:00 PM
1991 Deville won't start. Engine is a 4.9 automatic. Is there a place to plug in a code reader? Tried the "off/warmer" to pull codes and not getting anything, meaning car doesn't seem to be going into code mode. The car is turning over. Checked fuse box and only middle row is showing hot. Since this isn't my car (my son just bought it) and I have absolutely no knowledge of this car, PLEASE be very detailed if you have any advice on what I need to be looking for or checking out. I really appreciate any help!!
caddydaddy
01-05-2008, 03:38 PM
Under the center of the dash is the OBD port to plug in a code reader.
Melitta
01-05-2008, 04:02 PM
I have looked under the whole dash. I am not finding a plug. Is it covered with something or anything like that?
Thanks!
Melitta
01-05-2008, 04:16 PM
OK, we found the port. Someone had shoved it waaay up under the dash. My code reader is giving me 52 Keep Alive Memory Reset. Any clue what that is?
Never mind...I found the code. That is the only code I got. OK, what we are seeing now is the car is not getting any spark. It will turn over and crank, kind of like it is out of gas (it's not). Where do I start...anyone???
caddydaddy
01-05-2008, 04:20 PM
That just means that the battery was dead or disconnected and the PCM memory has been reset.
I'd look into the basics for your no-start condition. Fuel, spark, etc.
caddysplat
05-04-2008, 10:30 PM
try changing your ignition control module they're a common problem it went bad on my 91 and the parts store guy said its a real common problem it fixed mine
maxwedge
05-05-2008, 03:42 PM
Welcome to AF, look at the dates before posting this is too old, thanks.
