2000 honda civic AEM short ram intake installationspecial_k188 02-19-2003, 08:27 AM If anybody can please either send me some sights that tells or shows me how to install a short ram intake into my 2000 honda civic that would be great. also if you know how and you wouldn't mind writing the steps down that would also be gratley appreciative. thanks for the help JuMBoBeaTS 02-19-2003, 12:24 PM its real easy... open up your hood... take the negative (-) off the battery... locate the airbox... its a big black box on you lower left if your facing the engine... theres i think 3 or 4 screws u hafta remove on the outside n i think one inside tha filter box... once u get those out... pull out that black box... then what should b left is a tube goin to the intake manifold (there will also be another tube under the box but u dont need to take that out since u have short ram)... look on that tube goin to the intake manifold n there should b 2 things connected to it... a hose and a plastic piece... carefully and i mean CAREFULLY remove the plastic nipple... thats your oxygen sensor, break it n u gotta take a trip to honda for another one... the other tube is a breather hose i think... now at the intake manifold, there should b a ring clamp... loosen it and pull that black tube of... now take the intake tube and assemble it if u already didnt... then use the provided hosing (i forget what its called) but its it should fit over the openin of the intake manifold... put them in this order... hose - ring clamp - ring clamp - intake pipe... now tighten the clamps... now on the intake tube, there should b a nipple, but the breather hose there... make sure its on good... what i did was use a lil soapy water to get it on... n then there should b a hole in the intake pipe n they should have provided u with a grommet u can insert... once u do that... place the oxygen sensor in there carefully... reconnect the negative (-) and start the engine and let idle to normal temp... dont rev the engine cuz the ECU has been resetted and its doin a system check... after that... the fun part begins... test drive!! thats pretty much it... oh and some word of advice... do a search first next time... most of Q's have been answered here many times... but ure a newbie so im bein nice... special_k188 02-20-2003, 02:39 AM hey man just to let you know that the newbie as you like to call me just got the intake installed within 20 min. without using your instructions. so theres your newbie for you.:flipa: c_digg 02-20-2003, 02:45 AM pff, such gratitude LOL JuMBoBeaTS 02-20-2003, 02:05 PM Originally posted by special_k188 hey man just to let you know that the newbie as you like to call me just got the intake installed within 20 min. without using your instructions. so theres your newbie for you.:flipa: then y did u ask for help??? damn, i was just tryin to help u out... i only called u a newbie because u r a newbie to this forum... it even says newbie under your name.. B16EJ1 02-20-2003, 02:15 PM Originally posted by special_k188 Hey thanks for the help and here have a kick in the balls:flipa: Dang!!! For you to have to post to install an intake classifies you a newbie anywhere you go. special_k188 02-20-2003, 06:46 PM my bad man, i told my friend to reply for me and i just read what he posted. sorry about that. thanks again for the help. it worked out good. CustomWhips 02-20-2003, 08:24 PM what an ass. i didnt ask any instructions when installing mine in a few minutes it doesnt take a genius . very simple ... but for real what an dick.. Automotive Network, Inc., Copyright ©2012
