what wire????acme1 01-05-2008, 04:12 AM I know this has probably been mentioned several times but I cant seem to find the answer when I search. . . . I have an 87 crx si that I am swapping the engine out from a donor 87 integra, from what I've read I dont think I will have many problems with the swap but wiring is not the best thing I know how to do. I have read that in order to do this I need to swap 1 wire but which wire is it? I have both complete cars only the crx's engine has seen better days and the teg needs a fuel pump. I have to do the swap this weekend so I can be at work monday so any help would be GREATLY appreciated. The more specific you can be on the wiring the better. Thanks in advance. lxndr 01-07-2008, 05:35 AM Here's a link to a nice write-up a good friend of mine put together: http://www.redpepperracing.com/forums/index.php?showtopic=20659&st=330&p=261830&#entry261830 acme1 01-17-2008, 08:41 PM Thanks man, great link. The swap went great and the car has way more pep. I am having a little trouble with the cold starts though, I have to give it gas to get it to start, anyone else have this probloem after the D16 swap?? Christ 01-22-2008, 05:37 PM is it carb'd or FI? Carb'd, check the choke, FI, take off the IACV and clean it out, or just replace it. Also, I think you were supposed to change the fuel pump, etc, if you were going FROM carb TO FI... if you didn't do that, I'm surprised it even starts. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
