Re: Fair cost of part+labor: Serpentine belt, 03 Camry
Pretty much every mechanic shop out there, uses the National Labor Guide for reference. That is a way to make things a little more fair across the board. Some shops may charge more per hour, some less. The average rate is roughly $65-$75 per hour. So yes, you might be able to find a little cheaper price, as the shops labor rate varies from shop to shop. It is only fair, as they all have overhead, skills, tools, etc they need to pay for.
On the other hand, looking at the labor guide, I believe they are incorrectly adding everything up. Here is what the guide states for your issue;
Drive Belt
Replace
AC Belt 0.5
NOTE
Each Additional Belt, 0.2
Alternator Belt 0.4
NOTE
Each Additional Belt, Add 0.2
P/S Belt 0.6
NOTE
Sounds like they are adding the labor up as if you were to replace each individual belt independently. For instance, if you came in one month, and needed the PS belt replaced, then a few months later you needed the Alternator belt replaced, then a few months more the AC belt. Those particular rates for each item is listed in bold.
However, since th PS belt is already removed to get to the AC belt, the correct charge for the other belt should be the 0.2 hours, since the belts are already off. Make sense?
So, if I were to bill that job, going off the Labor Guide, I would charge 1.0 hours. You start with the "hardest" belt being the power steering belt at 0.6 hours, then add each additional belt ie. 0.2 hrs x 2 + 0.6 hrs gives you a total of 1.0 hours. A savings of roughly $35-$40 or 0.5 hours of labor.
That's not to say that a skilled technician can't complete the job faster, and correctly. That is an incentive for him to get the car in, taken care of, and move to the next job. A tech like this could easily bill out 10-15 hours in a day, while actually only working 8. Thats part of being a skilled mechanic, and knowing your job well.
So, knowing this you can either go back to the dealer and explain all this to them, as I can pretty much guarantee they are using the same program I am. Or, find a shop that would have estimated it this way to begin with.
