suspension setupproject drift-10 01-04-2008, 04:05 AM does any one have any idea on how to setup suspension for drift on a 94 s-10 midgetracing28 01-21-2008, 04:28 AM you gotta set of scales handy? %48-51 rear weight (ull prolly have to mount a fuel cell or lead weights )with a big sway bar out back low as possible wih -1.5 to -2 degrees camber on the front end with 1 degree positive caster. would be a good starting point o and toe out both front tires about 1/4 inch at the track and these are not good for the street so i hope you can adjust them for track and street use. If your serious about it you could invest in a set of adjustable rear shackles and weight jacks for the front its how we set up leaf spring dirt track cars which are alot more picky than a drift car. Automotive Network, Inc., Copyright ©2012
