2000 Expedition 5.4 won't move
radeck
01-03-2008, 01:16 PM
My 2000 expedition would not leave the driveway. Engine is running, but when I put it on rewerse, it's like it has no enough power to move up the driveway. It will move one inch but no more. Before it was making whining noise while driving, especially when stopping on lights and accelerating from stop. No noise while on neutral or park. Any ideas. Also while I was trying to move it at some point overdrive started blinking and CES came on.
Turbokid15
01-03-2008, 04:52 PM
Check your tranny fluid level.
JoeShmoe
01-03-2008, 11:36 PM
Sounds like you blew a solenoidn in the tranny:banghead:
Although I really don't know if its something you could change yourself.
radeck
01-03-2008, 11:38 PM
I did. It seems to be too high. Could this be a reason?? Car actually did move after I was idleing it for about an hour, when transmission got really hot. Then when it cooled down, same problem. Track won't move again. Any help?? How abbout this fluid? should I drain it?
JoeShmoe
01-03-2008, 11:59 PM
I've heard of too much fluid being bad but I doubt it will help to drain it.
rhandwor
02-24-2008, 07:33 PM
Pull the transmission dipstick and smell it if it has a burned smell to it a rebuild is probably in order. I changed the shift solenoid on my 1997 with a E40D transmission. At that time the pack of solenoids was around $60.00 and a new filter kit with gasket was around $25.00. This is a job a decent home mechanic can handle.
Your going to pay big money if you go to a shop.
radeck
02-26-2008, 04:17 PM
Well, problem is solved. New transmission and new torque converter did the job. Cost me about $1500 plus 8 hours of really heavy work.
JoeShmoe
02-27-2008, 08:13 AM
Glad to hear that.
79Corona
03-25-2008, 11:39 AM
I was going to suggest checking the parking brake. ;)
