Field Sfc-Vtec COntroller HELP
Marco_B20Vtec
01-02-2008, 12:20 PM
Hey All
Can anyone help me with a Field SFC Vtec controller
i dont think mine is setup properly
thanks
Greenblurr93
01-02-2008, 01:25 PM
hmm... a little explination of whats going wrong would help greatly
Marco_B20Vtec
01-03-2008, 12:42 AM
Good morning,
Well the main problem at the moment is that the Rev's on the COntroller read less then they are on the dash rev counter.
So basically on the controller VTEC is set to kick in a 4200rpm and shift beep at 6300 or something. even at idle its showing 600rpm and the needle looks to be around 900.
the other thing is the previous owner removed the casing so i dont have a cover for it.
thank you
Greenblurr93
01-03-2008, 08:36 AM
not much you can do about the case other than make one, or find another one... as far as the reading... i would first make sure you have the wire hooked up to the correct wire in the factory harness, if it is, then i would make sure the connection is as strong as possible. I recommend soldering all connections
Marco_B20Vtec
01-03-2008, 08:45 AM
thanks a mill.
making one is going to be a mission, but i will try my best.
ok i will check, as far as i can see the connections are not soldered! so i will try that !
thanks again !!!
azlana
01-10-2008, 01:57 AM
Hi all,
Anyone can help me find Honda Torneo 1997 Auto Electrical schematic..
Also How to wiring Apexi SAFC1.
Actually I just brought Honda Torneo Auto Halfcut and need to swap to my Honda Accord 2.0 1990..Plzzzzzz
