my speedometer is not working i was wondering if any of you could help me out with instructions in how to change that cable/wire. I own a 1993 ford probe GT. Thanks in advance for your info.
venx
I have a 89 Probe. I changed the cable before. The cable should be 2 pieces. So you have to check both half to see which is broken. If its the upper cable you might have to remove the speedo. The lower is easier to change. If you need a cable let me know.
my 93 pgt speedometer doesn't work eithier but they told me it was the vss speed sensor can you help me?...mine also won't shift in the last gear..automatic...does yours ?
