Re: key fob unlocks, but does not lock?
No expertise here, but some lines of logic. You could have a worn or dirty contact in your fob or you do have a weak battery that happens to have a harder time getting current through that one switch contact that could be just a wee bit dirty. See if it still works as far from your car as it used to or what the manual says its range should be. I'm not sure if it can be opened enough to clean it, an electronic cleaner is best. Brake cleaner will probably work with a q tip or pencil eraser, but then needs to be rinsed. Spraying inside it without opening it to the contacts is worth a try. I don't think the batteries are too expensive, so it would be easy to rule out the batteries. Let us know what was wrong.
