1998 Chevy Venture Air Filter
venturenot
12-30-2007, 07:20 PM
How do you replace an Air Filter on a 1998 Chevy Venture?
I unfastened the clips but due to clutter cannot open it far enough to remove and replace the filter. Is there something easy that I am missing, or is this just poorly designed?
Thanks,
'97ventureowner
12-31-2007, 01:05 AM
Try this link for help in changing your air filter:http://www.automotiveforums.com/vbulletin/showthread.php?t=336997 .
bigcoconut
12-31-2007, 01:44 PM
On my 99, I've found it easier to remove the large rubber ribbed air intake hose between the air filter housing and engine inlet. Once the hose clamps, electric connections and vacuum hose connection are loosened you can wiggle the hose free and out. With the hose gone you can open the air filter side door enough to get the filter out.
Good Luck...
rockwood84
01-12-2008, 01:43 AM
a few good stiff drinks before you start on it helps alot too. yeah get the throttle hose out of the way and it makes it easier,didn't say easy cause it ain't .
