2006 TahoeMatts01ES 12-28-2007, 06:10 PM On my 06, where the temperatur adjustment nobs are that slide up and down, I had one go out. Does anyone know the bulb that is in there and how to replace it. thanks in advance 16th hippy 12-29-2007, 04:20 AM don't know if bulbs can be replaced, but gently pull the trim plate off. set parking brake, set tilt wheel to lowest position, and gearshift on low gear(NOT RUNNING). this makes getting trim plate(bezel) off so much easier. remove the 7mm screws holding climate controller and there ya go. like i said though, not sure if bulbs can be replaced. Matts01ES 12-29-2007, 07:34 AM hey thanks for the write up, I check it out 16th hippy 01-08-2008, 05:47 AM no prob. Automotive Network, Inc., Copyright ©2012
