98 pathfinder - no low beamscorli1 12-28-2007, 02:59 PM My low beams dont work... i checked the fuses and there is a fuse for HIGH BEAMS but not for lows... i tried changing the lamps, to no avail... The did not go at the same time... one went out and then a week later the other went... The high beams work fine. I maxed out my budget over x-mas and cant afford to bring it to the shop. Does anyone have an idea on how I can fix this? I'd prefer not to drive with my high beams on for safety reasons... Thank you. C. 88pathoffroad 12-29-2007, 05:15 PM Have you checked the fuses under the hood for the low beam or DRL fuse? Sometimes the DRL module will take a crap and require replacement. (daytime running light) Sometimes the headlight switch goes out too. That would be the next place to look and troubleshoot. Automotive Network, Inc., Copyright ©2012
