Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-28-2007, 12:00 AM   #1
rimfire,22
rimfire,22 Normal reputation
engine steam cleaning
Hello to all,
Happy Holidays and a joyest New Year.
I want to steam clean my engine from my 89' Camry and can't get any Toyota dealership to handle this. Why??
I recently found a car wash that can handle this and want to find out if their are any concerns I need to worry about before proceeding. My enigne is pretty filthy. I think my engine will run better cleaner.
Thank you all,
rimfire,22
rimfire,22 is offline   Reply With Quote
Old 12-28-2007, 09:20 AM   #2
DFBonnett
DFBonnett Normal reputation
Re: engine steam cleaning
It won't run one bit better cleaner. Steam cleaning is pretty drastic. We used to do it a lot back in the day, but that was before all of the electronics. You might be better served using an engine degreaser spray followed by a gentle rinse. Repeat as needed.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 12-29-2007, 01:02 AM   #3
rimfire,22
FWIW
YMMV
DFBonnett,
I went ahead and had the procedure done. I was a quick 30 minute wash including a pass through the car wash. The shney stuff they sprayed on look nice. I gave it a good drive and everything seems to work fine. Perhaps they did just what you described. Regardless I'm happy.
Thanks for your response.
rimfire,22
Old 01-02-2008, 01:41 PM   #4
jdmccright
The RustBuster
jdmccright's Avatar
jdmccright Normal reputation
Send a message via MSN to jdmccright
I tend to shy away from steam cleaning, but I do like to power wash the engine block, radiator, and other lower areas that collect grime. The steam can soften vacuum hoses (to the point where they don't fit snugly over the metal tube) and can even remove paint from the inner fenders if not careful.
Just beware to only wash the engine when it is cold and keep from spraying directly at any electrical looms and the intake assy. Use a fan-pattern spray. Presoaking the engine with degreaser helps too. Make sure to rinse it all off well. If you have access to an air compressor with a blow-off attachment, use that to dry off the electrical looms, other wires/cables, and alternator.
After rinsing, start the engine and idle for a minute or two to let the belts and pulleys dry off. If it has difficulty starting, then either you got some water in the intake or you have an electrical short. Check the tighness of the hose clamps, let it dry and try again (or use aforementioned air compressor). Likewise if your alternator light comes on...once it dries out, the light should turn off. If not, then something has been knocked loose or water has gotten into a connector.
Claims of a cooler or better running engine by keeping it clean are mostly bunk. You'd have to have ALOT of buildup to get any insulative results, and in that case you've got more serious problems than just a dirty engine. Keeping the INSIDE of the engine clean is the important thing. Hope this helps.
Current Garage:
2003 Pontiac Vibe 1.8L AWD
2003 GMC Envoy XL (aka "fat-a$$") - K&N air filter, otherwise stock.
1995 Chevrolet C2500 2wd, 5.7L - K&N air filter, otherwise stock...my weekend hauler.
1992 Toyota Camry LE 2.2L - K&N air filter.
Vehicle History:
2004 4.7L Dakota Quad Cab 4x4
1996 GMC Jimmy 4wd
1992 Chevrolet S10 Ext. Cab 4.3L
1995 Honda ST1100...my first (and only) new vehicle.
1980 Yamaha XS400
1980 Mercury Bobcat...my first car.
jdmccright is offline   Reply With Quote
Old 01-10-2008, 01:26 AM   #5
grandamlv
grandamlv Normal reputation
A grate way to dry off or dust off things is to use a leaf blower. It sounds crazy but it works. It has a lot of air volum I have used it on many things. I dont recomend using an electric one with water!!!
grandamlv is offline   Reply With Quote
Bookmarks
Google
Web AF
