Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mercedes-Benz > SL
Old 12-24-2007, 08:54 PM   #1
Hesam
Hesam Normal reputation
Unhappy 1996 SL500- Top/Rollbar buttons Stay Lit(red) After Dead-battery Jumpstart
Can someone please tell me what could be wrong when initially my top unlocked/locked and softtop worked fine, then when battery went dead overnight and I jumpstarted the car the top-button and roll-bar button stay lit(red) and they don't work. I moved nothing related to the tops and top worked before battery died.
Should something get re-set to get the buttons working as radio and windows do in this car after battery disconnects?
Hesam is offline   Reply With Quote
Old 07-26-2009, 10:28 AM   #2
claytonbay
claytonbay Normal reputation
Re: 1996 SL500- Top/Rollbar buttons Stay Lit(red) After Dead-battery Jumpstart
Hello, i hope you still check this site. I just had the same problem with my 96 SL500 and tried to find out whats wrong, luckly i found your post. the only problem i have is, im in Japan and the dealers here want my arm -n- leg just to reset the codes. Do you have any advise? Is the diagnostic the only answer?
claytonbay is offline   Reply With Quote
Old 07-26-2009, 01:11 PM   #3
Hesam
I had mine fixed almost a year and half ago.
All I did was to take it to a nice mechanic who had the Mercedes Diagnostic computer, he connected his laptop computer to the car's computer which is in front of front passenger under the hood then he RE-SET all Fault-codes.
After he re-set everything and cleared the codes, the top buttons got back to normal and started to work. He didn't charge me and it took only 5minutes.
If your car battery ever needed jump-start make sure the switch is OFF then disconnect the battery, then charge the battery while it's separate from car's computer, then re-connect the battery and start.
Do not jump-start the Mercedes with another car, it messes up the computer. This car's computer is like airplane computer, too sensitive.
Good Luck
Hesam(from Iran)
Old 07-31-2009, 10:10 AM   #4
eclass
eclass Normal reputation
reset your window memory, first hold the window switch (in the halfway down position, not all the way down) to roll down the window, wait 3-4 seconds then roll it up the same way. perform this to both windows.
if the memory of the windows is not learned the top will not work. if it still does not work- sorry it is scan tool time.
eclass is offline   Reply With Quote
Bookmarks
Google
Web AF
