Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Nonspecific
Old 12-24-2007, 02:01 PM   #1
snazynismo
snazynismo Normal reputation
1949 plymouth restore
I was hoping to find some one to talk to about switching the master cylinder on my '49 to an upgrade or just the best way to go about restoring it and any other tips would be appreciated!!!
snazynismo is offline   Reply With Quote
Old 12-25-2007, 12:52 AM   #2
denisond3
denisond3 Normal reputation
Re: 1949 plymouth restore
There are firms that will take your old master cylinder, bore it out, install a brass or stainless steel sleeve, redrill the various ports and reassemble with new rubber parts. Its pricey, but combined with using DOT-5 fluid (not compatible with regular brake fluids like DOT-3 or DOT-4) will let your brake system last decades. You could locate such firms with a google search, or look around at www.hemmings.com. And you should probably do the same with the wheel cylinders, also get all new brake hoses, and do an inch by inch inspection of all of the brake lines - looking for corrosion. There is no system more important on any car than its brakes.
I would also advise keeping the entire vehicle original, since a 49 Plymouth is able to handle most modern traffic cruising and stopping needs, without being 'upgraded' - which some antiquers think of as bastardizing. Anything non-original, is likely to cut into the interest other antiquers would have in buying the car. $$$$
Good Luck... They were neat machines.
P.S. I would not set the intake/exhaust valve clearances to the factory specs. It is likely to make it hard to start when the engine is warm. Add an extra .002" to the clearances. It will make a slight increase in valve noise - but it will start on the first turn of the crankshaft. Also be sure to use a fuel additive to replace the lubing effect of tetraethyl lead - for longer valve life.
denisond3 is offline   Reply With Quote
Old 12-25-2007, 11:42 PM   #3
snazynismo
Thanks alot great advice!!!
Bookmarks
Google
Web AF
