bumby as he!!
djnoodle
02-16-2003, 12:05 PM
i dropped my car this weekend with dropzone coilovers. i put them on my stock shocks. they didnt come with instructions and i have never done that before, i was only armed with my haynes. well, we got the coilovers on and we set the coilovers the same for all 4(about 3/4 of an inch below the screws on the coilovers adjustable part) i drove it home last night and a little this morning and DAMN is it bumby as fu%&. i dont know if its because i have a donut on the back or if the springs are just brand new, anybody have an knowledge on this?
djnoodle
02-16-2003, 12:11 PM
heres a pic today
sparq
02-16-2003, 04:07 PM
Im sure the fact that you have a doughnut on your back is probably throwing your suspension out of whack. Get same size tires all around and then check.
Vtec
02-16-2003, 06:02 PM
Well for starters coilovers are not meant to be used with stock shocks so that don't help much for your ride and I'm guessing there a real aggresive spring with a high spring rate more for like running on the strip. Your best bet is to try some new shocks.
Rice-Rocketeer
02-16-2003, 08:41 PM
Damn meng, Joo on hydros.
djnoodle
02-16-2003, 09:06 PM
why is the front higher than the back even though i set them pretty much the same
Vtec
02-16-2003, 10:27 PM
my coilovers are the same way you have more adjustment in the rear then in the front so just give a couple extra turns in the rear then in the front and it should level out.
shepworldwide
02-17-2003, 08:11 AM
look at that fender gap...
are you sure you put coilovers on :confused:
djnoodle
02-18-2003, 10:39 AM
yeah, i put them on, but i wanted to keep it high so when i get my rims today or tomorrow i can put them on and lower the springs from there
limitk7
02-19-2003, 12:17 AM
The bumps in your ride are the death spasms of your stock shocks, which can't effectively handle the lower ride. Plus, having coilover sleeves doesn't help. Sleeves on stock shocks ride harsher than lowering springs on stock shocks. You probably want to get some aftermarket shocks soon...or you can wait a little while, but your stock shocks will probably wear out.
