| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
02-13-2003, 08:40 AM
Recoloring Interior
I HAVE BEGUN RECOLORING THE INTERIOR ON MY CAR, THE PLASTIC PIECES I HAVE USED A METHOD I FOUND ON THE BOARD AND IT HAS WORKED VERY WELL NO CHIPPING OR ANYTHING TOOK A GOOD 2 WEEKS DIDNT WANNA RUSH AND MESS IT UP.
NOW MY QUESTION IS WHAT METHOD IS BEST FOR RECOLORING THE VINLY AT LEAST I THINK ITS VINYL.
IVE READ ON THIS BOARD ABOUT PAINTS AND DYES FOR THE VINYL. WHICH IS BEST?
DOES ANYONE HAVE A FAQ OR INSTRUCTIONS THEY COULD HELP ME OUT WITH?
I DONT KNOW IF IT HELPS BUT THE VINYL IS BLACK/GRAY AND I WANNA GO TO WHITE I THINK DOES THAT MATTER?
I KNOW ITS A LOT OF QUESTIONS BUT I JUST WANNA GET IT RIGHT THANKS ALOT GUYS
XXDCMAST
02-13-2003, 12:42 PM
Go to www.G2USA.com they have some good vinyl dye or so ive heard. Im gonna order mine soon  . Im also heard of SEM vinyl dye. I dont think it really will matter much that your vinyl is black/grey just make sure you get some vinyl prep so the vinyl will "suck up" the dye better and the color will soak in.  Good luck with you interior. Im gonna head over to canadian tire soon and grab the stuff I need to start doing my plastic parts. Which method are you using for them?
02-13-2003, 02:31 PM
NOT SURE ITS ON THIS BOARD SOMEWHERE I HAVE IT AT HOME I CAN POST LATER FOR YA. BUT BASICALLY I FOLLOWED THESE STEPS.
WASH PIECES THOROUGHLY
1. SAND WITH 320 GRIT SANDPAPER MAKE SURE ITS SANDED NICE HELPS THE PRIMER STICK
2. PRIMER USE A GOOD 4-5 COATS OR MORE SAND LIGHTLY IN BETWEEN WASH AGAIN AFTER
3. PAINT WITH ENAMEL PAINT USE 4-5 OR MORE COATS SPRAY LIGHTLY TOO MUCH WILL RUN. SAND AFTER FINAL COAT AND WASH AGAIN
4 SPRAY 3-4 COATS OF CLEAR ENAMEL SPRAY
LET DRY FOR A GOOD TWO DAYS TO MAKE SURE THE ENAMEL IS NICE AND HARD.
LOOKS GOOD TRYIG PEELING IT OFF SEEMS STUCK THERE PRETTY WELL
THE MORE TIME YOU TAKE ON IT THE BETTER IT WILL LOOK DONT TRY TO RUSH
02-13-2003, 03:50 PM
What exactly is enamel paint?
So i put the primer coats on and then sand it and wash it?
and I do the same with the paint and clear coats?
Did you check out the vinyl dye's?
02-14-2003, 12:40 AM
here's what your vinyl will look like if you use g2 vinyl dye. btw, this is my interior
98 Civic Ex Coupe
02-14-2003, 01:06 AM
yea but wouldnt the paint crack easy on the door pannels since it is that squisy vinal material. i am saying if u were to push on it getting in or out of the car i figured it would crack i could be wrong?
~Google learn how to use it.~
02-14-2003, 01:41 AM
its not paint on the vinyl part. its "dye" which does just that. it soaks into the vinyl, dying it and permanently changing its color. Nothing is sticking to or on top of the vinyl. The vinyl is now that color. if you cut the vinyl, and looked at it from the side, the color of the vynil would be the color you dyed it. i can push on the vinyl parts all day long, and it'll flex a little bit just like it did before, without any cracking or whatever. basically, the vinyl is just a new color, and thats it.
98 Civic Ex Coupe
02-14-2003, 04:26 AM
its like dying your hair.....if you dye your hair and push on it does it crack and fall off?
02-14-2003, 08:05 AM
AF Premium User
WHY MUST YOU PEOPLE TYPE ENTIRE POSTS USING THE CAPS LOCK BUTTON?????
AF's Official Asshole
RIP AUNIE
02-14-2003, 08:56 AM
BECAUSE IM AT WORK AND THEY ARE AUTOMATICALLY ON NO MATTER WHAT
02-15-2003, 02:03 PM
Damn, that looks tight. How do u use dye? same as spray paint? how do you dye the dash part? do you have to take everything off the car??
Cool Air Intake
Revolution Exhaust
17" Enkei's
205/40/17 Nankang NS-1
Neuspeed Sport Springs
Tokico Blues
02-15-2003, 03:19 PM
to use dye, you have to first spray a vinyl/plastic prep solvent onto the vinyl to dry it out. This way it'll suck up the dye sorta like a sponge. once you've done that, then just spray the dye directly onto the vinyl. it'll soak it up just as easy as that.
98 Civic Ex Coupe
02-15-2003, 03:20 PM
i kept my dashboard in the car, and just took everything removeable out of it. then i taped everything off, and used the procedure i described above.
98 Civic Ex Coupe
02-15-2003, 04:14 PM
AF Premium User
WELL THEN MAYBE YOU SHOULDNT BE SURFING THE INTERNET WHILE YOU ARE SUPPOSED TO BE WORKING...
RIP AUNIE
02-17-2003, 04:51 PM
MAYBE YOU SHOULDNT BE A COCK 90% OF THE TIME
