96 ES300 Keyless Entry Programming???tigerpilot 02-12-2003, 02:40 PM Help!! I need the key programming instructions for my '96 ES300. I have them for 1998 but I think they are different 'cause they don't work. rheeric 05-17-2003, 12:41 PM Hello. Did you ever figure this out! I have a 1993 and need the same info? ssdave 06-23-2003, 11:07 AM 1993 KEYS CAN NOT BE PROGRAMED 1996 SHOULD BE AS FOLLOWS UNLOCK DOORS- OPEN DRIVERS DOOR-INSERT KEY IN IGNITION & PULL OUT-LOCK & UNLOCK DOORS 5 TIMES W/DRIVERS SWITCH-CLOSE DOOR-OPEN DOOR-LOCK & UNLOCK 5 TIMES AGAIN-INSERT KEY IN IGNITION & TURN ON THEN OFF ( DO NOT START CAR ) PUSH BUTTON ON KEY FOR 2 SEC.-CLOSE DOOR-OPEN DOOR &PUSH BUTTON AGAIN ! THIS SHOULD WORK , IF NOT MAKE SURE BATTERY IN KEY IS GOOD. Brother Kain 10-29-2003, 03:54 PM 2 Quick Questions. Does this method work for a 1995 ES300? And the second question is: does this work for a key that is not cut for the car? I have a different keyless entry key; can I simply follow this procedure, using the working key to turn the ignition? Thanks 1993 KEYS CAN NOT BE PROGRAMED 1996 SHOULD BE AS FOLLOWS UNLOCK DOORS- OPEN DRIVERS DOOR-INSERT KEY IN IGNITION & PULL OUT-LOCK & UNLOCK DOORS 5 TIMES W/DRIVERS SWITCH-CLOSE DOOR-OPEN DOOR-LOCK & UNLOCK 5 TIMES AGAIN-INSERT KEY IN IGNITION & TURN ON THEN OFF ( DO NOT START CAR ) PUSH BUTTON ON KEY FOR 2 SEC.-CLOSE DOOR-OPEN DOOR &PUSH BUTTON AGAIN ! THIS SHOULD WORK , IF NOT MAKE SURE BATTERY IN KEY IS GOOD. rheeric 10-29-2003, 04:46 PM I believe it should. It does not matter on the cut of the key. I do know that like my year car (1993) has a chip in the key and near the antenna and has to have matching chips to work Brother Kain 11-03-2003, 03:45 PM Well I tried this method on my 1995 ES300, and I can confirm that it definately will work. I now have 2 master remote keys that work for my car, even though I got them off of a different car, so the cut is totally different - at least the keyless entry works. Thanks!!! 1993 KEYS CAN NOT BE PROGRAMED 1996 SHOULD BE AS FOLLOWS UNLOCK DOORS- OPEN DRIVERS DOOR-INSERT KEY IN IGNITION & PULL OUT-LOCK & UNLOCK DOORS 5 TIMES W/DRIVERS SWITCH-CLOSE DOOR-OPEN DOOR-LOCK & UNLOCK 5 TIMES AGAIN-INSERT KEY IN IGNITION & TURN ON THEN OFF ( DO NOT START CAR ) PUSH BUTTON ON KEY FOR 2 SEC.-CLOSE DOOR-OPEN DOOR &PUSH BUTTON AGAIN ! THIS SHOULD WORK , IF NOT MAKE SURE BATTERY IN KEY IS GOOD. johnnyb_great 11-12-2003, 03:19 AM Obviously many who would like to know concidering this thread has been read 400 times! Including me and my 94 ES. Anyone called Lexus 888-25-LEXUS? crazyhorse425 02-20-2005, 02:15 PM i bought a new key from this lexus-parts website, and will the programming procedure work for that new key? rheeric 02-20-2005, 10:05 PM i bought a new key from this lexus-parts website, and will the programming procedure work for that new key? Hey crazyhorse which year do you have? crazyhorse425 02-21-2005, 06:56 PM NVM, i programmed the key just by following the steps, BUT, to make it clear, when u hear the beep, press the buttom for at least one sec then release, its gonna beep like 3 or 4 times, then after its done beeping, close/open door, then press the buttom again for at least one sec, and then wait 20 sec and try ur key. the key should work.... i got 96 es 300...and just done a 60k maintainese...and its $500 bucks....coz 60k has longer list than 90k...lol crazyhorse425 02-21-2005, 06:57 PM and that maintainese doesnt even include replacing spark plug and $60 for replacing a fog light bulb?....its so not a rip off, its a damn robbery!! rheeric 02-21-2005, 11:06 PM and that maintainese doesnt even include replacing spark plug and $60 for replacing a fog light bulb?....its so not a rip off, its a damn robbery!! LOL I heard that man. I had a 94 model. Just got rid of it yesterday for a 1991 Ford F-150 4x4. Very sad moment in my life. That was the best card...but I am NOT gonna miss the robberies of maintenance...LOL Heck yeah i will...i must, because i have already started trying to find another one...LOL Automotive Network, Inc., Copyright ©2012
