95 taurus - reprogramming keyless entry remote
mgbert
02-12-2003, 01:01 PM
I just baught a used 95 Taurus but it only came with 1 remote. So I bought a second remote from ebay which sent instuctions for reprogramming it. The problem is I'm ignorant as to how to "momentarily jump pins in programming connector", which is all the instructions say to do. What pins and where? do I have to open it up? I could use some extra guidance before I go and screw things up.
thepartsyouneed
04-18-2004, 11:03 PM
These instructions will work on Taurus models, 93 - 95:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in LR quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
These instructions will work on Taurus models 96 - 97:
Cycle ignition from OFF to RUN 5 times within 10 seconds, ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
