Removing Driver Side axel?robtabor 02-04-2003, 03:24 PM Help! I have a 1996 Sentra that I need to pull the axel from. I can pull it out maybe 3 inches and that's it... What is the secret/trick? Thanks, Robert grahamjk 06-03-2003, 07:01 PM Not Sure if this will help or not. I had to replace the Driver side Axle on my 95 Sentra GXE. At first it would not budge. I had to take a large slot screw driver and pop out the axle. Granted it only came out 3 in or so. Now if you are planning on reusing the axle D NOT do this next part. to get the axle out... I had to wood block the transaxle and use a prybar to force it out the rest of the way. What I found that the end of the axle has a wire clip that was catching and keeping it from coming out....... Automotive Network, Inc., Copyright ©2012
