SR20DET ECU wiring diagram needed
P11GT
10-09-2001, 08:37 PM
Following on from the Engine Swap thread, can anyone supply me with a wiring diagram of the SR20DET ECU that show all the components of the engine such as the sensors, injectors, distributors etc. This is so i can make a comparison with the wiring diagram of my SR20DE as found in the Haynes Manual. Basically, i have a Unichip which could be reprogramed to handle the SR20DET but need to know if the DET has any extra wirin/sensor, because i dont wanna change over the loom. Im trying to find out as much as possible before i do the swap, with minimal fuss.
P10DET
10-09-2001, 11:24 PM
YIKES! Good luck. Maybe one of the Kiwis can help you there. I don't know of anyone in The States with that. Maybe JWT and/or JUN, but they would probably not share that info (understandably so - especially since you will be using a piggyback box).
I hope you can find it though. If you do, can you scan it and post it? I know a lot of people would like that info.
P11GT
10-10-2001, 06:51 AM
Ive found a site full of pdf files for the schematics of a Sunny GTi-R the wiring diagram is amoungs them, check out the link
http://gti-r-oz.50megs.com/manual/manual.html
P10DET
10-10-2001, 07:01 AM
COOL!
Thanks for posting this resource. :D
G-Forces
10-10-2001, 10:32 AM
Is that link working for everyone else?
P11GT
10-10-2001, 12:11 PM
the link seems to be working just fine, what problems you having?
Ive spoke to an engineer and he told me, if i were to do a DET swap, best use the DET ECU and wiring harness. In most cases, once youve replugged everything, you'll probably be only left with applying 12 volts to the ECU and away you go! So if im gonna do it, i'll buy a GTi-R and transplant everything that i need over.
G22DET
10-10-2001, 02:38 PM
oh man...this is exactly what i needed a month ago...i would have been able to hook up my obd1 ecu and harness instead of using the obd2 ones. thanks for the info!!! GREAT link.
P11GT
10-10-2001, 04:18 PM
Well, thats determination for you. Im serious about doing this swap, especially now that i only have 149 BHP with all them mods:mad: My mechanic said it would be better to swap harnesses and ECU aswell, especially if im gonna buy a whole car to donate parts.
On a different note, my insurance will cover me for the swap, but they want double the premiun, thats around £2K !!!! This i just one company, im sure i can get cheaper, by the time ive done it. No immediate plans, just researching it all, but hopefully, this time next year, i'll have my P11DET:D
P10DET
10-10-2001, 05:48 PM
Luke, I didn't look at any of the diagrams, but I'm assuming they don't have the BB diagrams listed. If that is the case, the diagrams for the GTi-R would not help you. They are very different.
In fact, I'm still not clear why you couldn't use your OBD-I harness and ECU.
P10DET
10-10-2001, 05:50 PM
It would only be that simple if you get the MAF from the GTi-R as well. You would need the complete front end of the car to get all of the sensors, as well as the harness and ECU.
P10DET
10-10-2001, 05:53 PM
FWIW, I don't believe your dyno numbers. It's so easy to get bad data.
We still don't know what conversion they are using to get from wheel hp to flywheel hp. We don't know if they are correcting for atmosheric conditions either.
Something is wrong and it's not the CAI or the cams. They are well documented to make about 15-20 hp at the wheels.
P11GT
10-10-2001, 06:25 PM
I dunno anymore, i think im past caring now. All in all, ive got them installed and im happy with the drivability of the car, and i know its better than before, so im just gonna concentrate on the styling next, then the DET swap. Ive done all i can with this engine, pointless wasting anymore money on it. My monnies on the DET!! that'll be quicker!!
Hopefully over the next few weeks, i should get the styling done and i'll be a lot happier.
G-Forces
10-11-2001, 10:26 AM
Damn are they going to double the book value of your car too? Insurance companies are a bunch of crooks. Oh good luck with the swap. Don't forget to document the process and send it to gtir-install@g20.net. :D:D:D:D
