keyless programing anyone?
BInfamous17
02-02-2003, 12:20 AM
just wondering if anyone has instructions on how to program a keyless entry remote for a 00 protege..... thank you very much in ADVANCE!!
mrharper68
02-01-2004, 12:02 AM
1. Make sure there are no keys in the ignition and that all doors are closed
2. Open driver's side door
3. Insert key into ignition switch and cycle the key between the ON and LOCK positions 3 times
4. Remove key from ignition switch
5. Push the driver's side door sensor switch 3 times
6. Verify that the doors lock and then unlock.
If nothing happens, wait 40 seconds and start from step 3 again
7. Press any button on any transmitter twice
8. Verify that the doors lock and then unlock
If nothing happens, see note A
9. If you have only 1 remote, press any button on that remote twice.
If you have 2 or 3 remotes, press any button on any of the other remotes twice.
10. Verify that the doors lock and then unlock
11. If you have 1 or 2 remotes, press any button on either remote twice.
If you have 3 remotes, press any button on the 3rd remote twice.
12. Verify that the doors lock and then unlock
13. The codes should now be reprogrammed
Note A:
1. Hold down the driver's side door sensor switch
2. Verify that the doors lock and unlock twice
3. Start from step 3 again
djeanes
11-01-2004, 07:18 PM
will this also apply to a 2002 Protege 5, the dealer want 50 bucks to do this. All i did was replace the battery in the remote
IRhino
11-06-2005, 02:01 PM
And will it work for a 98 protege dx? Thanks for any response...
Onblsht
11-09-2005, 11:51 PM
Should work, its the same instructions for other 98 Mazdas.
untamedsr2006
03-31-2006, 04:46 PM
will this work for a 1997 mazda protege
