Won't stay running
Deanna
01-25-2003, 09:57 PM
My car is a 1987 Pontiac Bonneville 3.8L, car is hard to start, runs rough when started, stalls, cylinders are flooding with fuel, fouling plugs, any ideas??? :flash:
Swigz
01-25-2003, 11:41 PM
You may have a fuel pressure regulator that is blown out.
Scott 02
01-26-2003, 11:24 AM
Yeah, since it is flooding itself. Or the fuel pump is messed up. either that or your motor is about to go.:(
Deanna
01-27-2003, 10:53 PM
I replaced the fuel pressure regulator, fuel pump, and all the vacuum lines. The computer says troublecode "32". Does anyone know how to clear diagnostic troublecodes?
Scott 02
01-28-2003, 03:54 PM
Its got more detail than i can explain, but i took the time to find this for you so that you can read through it carefully. This might help your problem.
http://www.iequus.com/downloads/Spring_2001.pdf
bridget36907
04-08-2003, 10:29 PM
hey did you ever get this fixed?
Scott 02
04-10-2003, 03:04 PM
i wouldn't have a clue. that person hasn't been on for awile.:(
dracer398
07-10-2003, 01:41 PM
I know it's kind of late but I had the same problem on my 1989 Bonneville and found that the ignition coil pack was bad. You can test it by disconnecting the coil pack from the engine and using an ohm meter compare the resistance between the three pairs of coils. If you find one pair that is noticeably different then the coil pack is bad.
shrty_19
01-13-2004, 07:51 PM
I checked it out for you and according to the web site i found it is your
Exhaust Gas Recirculation (EGR) Vacuum Control.
