turbo problems
hondatool
01-25-2003, 07:04 PM
ok..this sux..my turbo is spooling..i can hear that..but when its time to boost it doesnt...i can feel it not boosting and my apexi AVCR just shows it in vacuum still...i think i have a leak somewhere..i dont think its compression leak..or in the downpipe..cuz its not louder than normal for the downpipe...but i do bottom out alot...im thinking maybe a leak in the exhaust manifold or maybe a crack or something with the welds...can someone help here..this sux..anyone have this problem...its a greddy 15g kit on a 99 sohc vtec
kicker1_solo
01-25-2003, 09:28 PM
clogged cat maybe :D
SleeperCivic
01-26-2003, 11:43 AM
Didn't you post this on a site already? Maybe another thread? I'm sure I've replied to it already. I think we've determined it's a clogged CAT.
Force_Fed_Hatch
10-24-2003, 04:44 PM
im kinda having the same problem with my turbo.....
its a greddy td04h and it spools up fine, but im only gettin 3 lbs.'s of boost. i tightened the arm on the internal wastegate, and even disabled the wastegate. and all i can get is 3 psi....would a clogged cat cause this problem?
SleeperCivic
10-24-2003, 06:04 PM
First off, don't screw with the actuator arm. You're just asking for trouble. Either use a MBC or EBC (recommended). Yes, your catalytic converter could be clogged up to a point only allowing so much air to pass through.
How to determine a clogged cat: Disconnect the cat-back section from the downpipe and see if your boost picks back up. If it does, you've easily discovered that your exhaust system is hindering the gas from exiting quicky.
brianssteg
05-31-2004, 12:22 AM
when i race someone when i let off the gas or shift gears my car smokes out the exhaust and some comes inside the car. what could it be?
unusualcivic
05-31-2004, 01:08 AM
it could be an old thread running through your engine and burning upon exit.
