Intake Questions
2K1 G20
10-05-2001, 11:12 PM
I gotta 2001 G20 what is the best intake(s) for it. (Stillen, JWT....) and how much would it cost?
BruinG20
10-06-2001, 06:04 AM
pop charger or cold air? JWT for pop charger and hotshot for CAI, in my opinion
Mrcoilover
10-06-2001, 01:17 PM
HOTSHOT CAI looks tha best to me. Got the chrome finish
pche059
10-06-2001, 04:13 PM
I have always wanted to ask this question....
what is the difference between a pop charger and a cold air intake?
both uses an air filter right?
which one gives more power?
the one i have got is "apparently" a CAI according to the guy who sold it to me....it did cost me a lot more than just an air filter....however it looks the same .... it .does sound a lil bit louder tho....
BruinG20
10-06-2001, 04:50 PM
They look very different. A pop charger, like JWT's is a little longer than the stock air pipe. And it has a better filter at the end which allows more air into the engine. But it is in relatively the same place as the stock filter. A cold air intake is even longer, and places the air filter away from the engine so that the air is cooler. For the G20, the cold air intake pipe leads to the lower front corner of the car. It's usually about 2 to 3 times longer than the pop charger. And it is a little louder than a pop charger.
The cold air gives around 2 - 4 more horses.
kenchan
10-06-2001, 07:40 PM
da longer pipe seems to help AT cars with the low torque too. :D
id say get the cold air intake cause its not worth sending hot air into the intake.
2K1 G20
10-06-2001, 11:04 PM
Which cold air intake do you guyz recommend, Stillen? How much would a good one cost?
greekman
10-07-2001, 05:51 AM
the stillen intake is a pop charger, not a CAI. for CAI i think hotshot would be your best bet. i have the stillen intake, which is essentially the same as the jwt intake except it says stillen on it. i got a pop charger b/c i didn't want to risk hydro-lock. if you live in a place where it gets wet on the road a lot (rain, snow,etc...) then you might want to reconsider the CAI. although it will give you more hp, i didn't want to risk it. if you live in a place where very wet roads aren't a problem, i would definitly recommend a CAI.
you might want to check out the classified section here, and www.se-r.net they have a good classified section for the sr20de (our engine). i know in the G20 classified section under lots of p10 parts for sale, drockg20 has a new hotshot CAI and a pop charger for sale. this is a assuming you have a p10.
2K1 G20
10-07-2001, 10:03 AM
thanks greekman
BruinG20
10-07-2001, 11:34 PM
an AEM bypass valve will help with the water lock problem. I wouldn't say that it would eliminate the risk, but it's probably good enough. Only problem is that nobody makes an intake that would fit nicely with the bypass valve (you have to do some cutting). Hopefully one day i'll get my stuff set up. I'm ordering a bpv from luke now.
Mrcoilover
10-08-2001, 09:58 AM
CAI is supposed to give around 8hp. Pop charger gets 3-4hp.:huh: :huh:
Nissan_2.0
10-08-2001, 11:27 PM
I purchased a Weapon-R Dragon for $205, and I've got a modest 6 horsepower gain from it. I looked at the Hotshot intake and chose the Weapon-R for looks, considering the 2-5 hp gains that the Hotshot might've given me aren't much anyway.
P10DET
10-09-2001, 12:39 AM
The Hotshot will yield as much or more hp as the Weapon-R.
GiNO805
10-09-2001, 03:35 AM
i know aem came out with one(since our engines the same as the sentra/2oosx se-r's) anyhow..also place racing has them...jsut thought i throw those brands in ohh adn the aem suppose to be street legal(carb approve if i remember or read right:0P)
