B16 Swap
hallison
01-17-2003, 12:24 AM
O.K. I HAVE EVERYTHING FOR A B16 SWAP EXCEPT THE WIRING HARNESS FOR THE B16 ENGINE. I NEED TO KNOW IF ANYONE CAN MAKE ME OR KNOWS WHERE I CAN GET A WIRING HARNESS FOR A B16 SWAP INTO A NON-SI '87 CRX WHILE NOT HAVING THE B16 HARNESS.
THE SAD FACTS.
1) NOT AN SI
2) DO NOT HAVE THE B16 HARNESS
3) REALLY REALLY REALLY NEED HELP
IF YOU WANT TO BY THE SWAP LESS THE WIRING HARNESS I MAY BE TALKED INTO SELLING.
HEATH ALLISON
heath.a.allison@verizon.net
rosendo192000
01-17-2003, 01:03 AM
b16a and tranny
ECU
Motor Mount kit
Rear Mount
Axles
Intermediate Shaft
CV Joints
Knuckles And Hubs
Radiator Hoses
1992 GS-R Upper And Lower
Throttle Cable
Speed Sending Unit
Brake Booster Hose
Cluch Cable
Cluch
1990-1991 Integra/ Disk
Pressure Plate PN ,
so u have all of this if so HOW MUCH ?
hallison
01-17-2003, 11:14 AM
OK I HAVE ALL THE PARTS THAT THE MECHANIC COULDN'T PROVIDE. ALL THE OTHER PARTS WERE INCLUDED IN THE INSTALL PRICE THE MECHANIC GAVE ME.
WHAT I HAVE AND WHAT I PAID.
B16A ENGINE AND ECU ($1,600)
ALL MOUNTS ($500)
SHIFT LINKAGE ($200)
AXLES ($250)
I WOULD REALLY LIKE TO SEE $2,000 AND YOU NEED TO HANDLE SHIPPING.
rosendo192000
01-17-2003, 11:20 PM
B16A ENGINE AND ECU <-----( w/tranny or engine only?)
ALL MOUNTS <-----(hasport ? and w/ the civic back mount ?)
SHIFT LINKAGE and AXLES <---(custom or hasport ?)
and i have ? i was just wondering how much would he do ur swap"MECHANIC" ?(i want to see if its cheaper then california)
thanxs
hallison
01-20-2003, 01:22 PM
1.) IT'S A B16 ENGINE, TRANNY AND ECU
2.) ALL MOUNTS WITH THE BACK MOUNT BUT THEY ARE FROM ARD PERFORMACE SAME AS ENGINE,TRANNY AND ECU.
3.) THE SHIFT LINKAGE AND AXLES ARE CUSTOM FROM HASPORT.
4.) TO BE HONEST THE MECHANIC WAS WAY OVER CHARGING BECAUSE HE KNEW HE'S LIKE THE ONLY ONE THAT WOULD CHANGE OVER MY NON-SI TO AN SI ALONG WITH DOING THE SWAP BUT IF YOU WANT I CAN CHECK AROUND SOME BUT IT'S PROBABLY NOT GOING TO BE ANY CHEAPER HERE.
I REALLY WANT TO FINISH THIS CAR BUT I CALLED HASPORT LAST FRIDAY AND THEY SAID SINCE MY CAR IS NOT AN SI I AM GONNA SPEND WAY TO MUCH CASH WITH THE CONVERSION, THE HARNESS AND THE SWAP THAT I SHOULD JUST BUY AN SI AND THAT'S MORE MONEY THAN I HAVE RIGHT NOW AND THAT'S WHY I AM TRYING TO SELL THE SWAP SO I CAN BY AN SI AND START OVER MAYBE WITH A B18 THIS TIME.
rnico
03-02-2004, 02:11 PM
so u do need motor mounts for b16 swap into 5th gin civic dont u use a combination of integra and delso mounts????
