i'm doing it. just waiting. i already bought the kit.
i bought a kit for the low beam bulbs. all i'll have to do is drill a hole in the housing for the wires. and i need to make a good ground connection. i already ghetto rigged it up to test if they work or not and they work perfect. the real install will come when my motor goes in.
Originally posted by markpa fugi whic ones are your low beams the inner or outer ones, and are u using the harness that came with them?
low beams are the outers. h3 bulbs.... i'm using the harness that came with the projectors. the HID bulbs get power the same way. except, the power goes thru the ballast.
