I wanna Install an RPM to my mirageyoungsense 01-15-2003, 09:31 AM I have an mitsubishi mirage 4dr 1.5 DE Automatic W/O tachmeter. I want to installed an tachometer . But I need the ignition coil wiring from the car . Or if someone have installed an Tachometer on a mirage like mine . Please send me some information on wich wire goes on wich wire . Thanks :) billybadass 07-26-2003, 02:36 AM okay this takes 2 people .1st u need a light power tester 2nd u find ur coil and then u need 2 s6tart ur car and have someone give it a little gas while u test each wire in the coil and then u will see one get brighter when they give it gas make sure u see it get brighter test other tomake final choice its very simple . velasquezjim1985 08-22-2004, 12:22 AM I installed a Tachometer on my 99 mirage, its very easy. The yellow cable goes all the way to the battery and hook it up to the possitive+. The red cable goes to the ignition. The black cable to the ground-. The green cable goes to the white cable that is next to the distributor. Its the only white cable next to it. If you want E-mail me at velasquezjim1985@aol.com and ill gladly take pictures of how I installed it. The only hard part was installing that one cable that tells you the RPM's, everything else is easy evoryda 08-22-2004, 06:31 PM OK i have the easiest way for the rpm signal there is a wire with a connector hooked to nothin that should be taped to the outside of a thick bundle of wires goin into the firewall on the left side if your facing the cars front. the connector is blue or brown and the wire is white and has groy dashes on it. connect the tach rpm signal to that and the rest should be simple enough. evoryda 08-22-2004, 06:33 PM sorry i meant gray dashes not groy. evoryda 08-22-2004, 06:36 PM hahahahahah ohhh snapp the first post was almost 2 yrs ago hahaha Automotive Network, Inc., Copyright ©2012
