Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-10-2003, 09:28 AM   #1
ixlar8
ixlar8
Question 92 Supreme 3.1L stall at idle- HELP
Runs strong, no trbl codes, replaced IAC. The 3.1L still stalls at idle when warm. Actually, the tach shows idle at 800RPM, then starts to osscillate from 1K to 500 then stalls! Any ideas??
ixlar8 (fast)
ixlar8 is offline   Reply With Quote
Old 01-21-2003, 04:39 PM   #2
Scott 02
Banned
Scott 02's Avatar
Scott 02 0
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
UT OH!!!
Scott 02 is offline   Reply With Quote
Old 01-21-2003, 06:00 PM   #3
Shortbus
All hail AF
Shortbus's Avatar
Shortbus +450Shortbus +450Shortbus +450Shortbus +450Shortbus +450
Send a message via AIM to Shortbus
It runs ok until it warms up?
If the car is running fine in closed loop(running using pre determined information from the prom), and then starts stalling when it switches to open loop(running using information from the sensors) that usually indicates the ecm is having trouble deciphering the information from all of the sensors. It's not a cheap fix but it is my best guess from the way you describe the way the car runs.
Good luck and hope this helps.
Shortbus is offline   Reply With Quote
Old 06-21-2003, 01:04 AM   #4
jschlat
jschlat
Does it start ok? could be a bad EGR valve.
If the ECM is having trouble, you may try disconnecting the battery for 5 or 10 minutes. This will force the ECM to loose all of its learned information, reset the IAC, reset the fuel pulse width to default, etc. Although if the ECM isn't setting any codes, I doubt it is the root cause of the problem. They are usually pretty good about detecting errors that relate to idle problems (or any thing else that could impact emissions)
jschlat is offline   Reply With Quote
Old 06-26-2003, 06:37 PM   #5
Flatrater
Main GM Guy
Flatrater's Avatar
Flatrater +150Flatrater +150
When ever you disconnect the battery or replace the IAC motor it needs to be reset! The reason the idle is surging is because the ECM does not know where to position the IAC pintle. There are 2 ways to learn the IAC setting one is using the GM scan tool to perform the function, the other is to let it idle for a couple of minutes in drive and then in park. Sometimes this works but it is easier to use the scanner. Call a dealer and ask how much they charge to relearn the IAC. In my shop we charge 30 minutes of labor for this.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Flatrater is offline   Reply With Quote
Bookmarks
Google
Web AF
