Problems with DET SwapMauiBlueGRide 10-02-2001, 06:27 AM Ok guys the motor is going into my 200sx but still its a SR20 and no one else has answered elsewhere. 1. Changed both coolant sensors, the TPS and the O2 (still having trouble getting the 32mm nut off) - but the Distributor and Coil plugs don't match - can I hardwire or do I need a different one of both? 2. Used JWT Lightened flywheel - looks ate to hell - there is material in the middle that can be replaced (bolts in back) - I never owned/worked on a 5spd - where would I get this resurfaced and who can I buy a new "center" piece from? Thanks guys Chris Long Sig for once.... '02 G20 Sport Maui Blue Ltd. Ed. STOCK '97 200SX SE - DET'izin it BlueBird SR20DET ACT Street Setup ES Motor Mounts JWT ECU/Lightened Flywheel SE-R Gauges/Shift Knob/Boot Short Shifter FMIC http://www.chrisstorer.com/turbo '93 NX2000 - Wrecked Needs Front End Pieces Http://www.chrisstorer.com/nx2000 www.evilegg.com on the way :-P P10DET 10-02-2001, 07:46 AM Originally posted by MauiBlueGRide 1. Changed both coolant sensors, the TPS and the O2 (still having trouble getting the 32mm nut off) - but the Distributor and Coil plugs don't match - can I hardwire or do I need a different one of both? The plugs from the harness don't match the plugs on distributor and coil - is this correct? I think that is because the B14 SE-R uses a different distributor and internal coil. They have to be swapped. Originally posted by MauiBlueGRide 2. Used JWT Lightened flywheel - looks ate to hell - there is material in the middle that can be replaced (bolts in back) - I never owned/worked on a 5spd - where would I get this resurfaced and who can I buy a new "center" piece from? Give JWT a call. Automotive Network, Inc., Copyright ©2012
