stupid ?sAdam 03-02-2001, 05:45 PM what is a compression ratio, bhp / liter, bore, stroke, lateral acceleration, EPA stand for, a sequential transmission, Final Drive, and what EXACTLY is displacement? carmaster 03-02-2001, 09:22 PM Bore is how wide the piston chamber is, stroke is how deep it is. EPA=Enviromental Protection Agency. Bean Bandit 03-03-2001, 07:11 AM bhp / liter = power(bhp) divided bz its displacement (in liter); displacement = An engine's total volume available for the charge, including both the swept volume (total range of piston movement) and the clearance volume (from the combustion chambers). During the 1960s displacement was usually expressed in cubic inches, often abbreviated as "CID"; lateral acceleration = This is a physical one. If an object wants to make a curve it needs a acceleration/force orthogonal to its direction. this force aims to the center of the circle the curve describes. e.g. the E36 M3 has a max. lateral acceleration of about 1g, means that you can't exceed this limit else your car will brake out and you'll lose control over it. for better explanation check a physics book and look for rotational movement; Compression ratio = (often shortened to "C/R") A measure of the pressure produced inside a combustion chamber when the piston is at maximum travel toward the cylinder head. This ratio is derived by showing the compression factor of the charge vs the constant ("1") of normal atmospheric pressure at sea level. For example, a typical 1960's "C/R" number would be shown as "9.5:1". Please note that our C/R statements often include the phrase "with service type gaskets". That's because the "factory" gaskets were significantly thicker than those sold by Ford dealers. Using these "service" gaskets commonly raises compression by up to half a point; sequential transmission = it's kind a half automatic zou don't have to do the clutching anymore. e.g. the Ferrari 355 Challenge has one; for the final drive my english vocabulary is lacking sorry:D enzo@af 03-04-2001, 03:17 AM final drive is basically the gearing at the diff, right? Bean Bandit 03-05-2001, 06:52 AM Right! Adam 03-05-2001, 04:09 PM thanx :D Psman32@af 03-12-2001, 10:15 PM Bean BAndit, your wrong. The compression ratio is the ratio as to how much smaller the compression area is then the whole stroke of that cylinder. Bean Bandit 03-13-2001, 05:14 AM To Psman32 I didn't wrote it, I copy pasted it from FoMoCo (http://www.fomoco.com/index.asp?Dept=4&Tool=0&Eng=0#cr) and I don't think they made a mistake. Besides your explanation seems right but very simple! TheMan5952 03-16-2001, 02:20 AM BHP=Brake Horse Power. They used to measure HP with a mechanical brake type thing that put pressure on the crank end, to usually measure the torque then calcuate the HP. How ever much force it could withstand then that was its BTQ (Brake Torque) Porsche 03-16-2001, 10:24 PM To add to the line of Questioning, why do they call Helicopter and boat engines' ouput "Shaft Horsepower" or shp? JD@af 03-18-2001, 09:06 PM What you two are talking about is the static compression ratio. A little more complicated is the dynamic compression ratio. I don't have a firm grasp of the differences between these two principles myself yet, but I should hopefully read up on it this week, and then add an updated post explaining the difference. And it is indeed a very important difference from an engineering standpoint with regards to high performance engines. Bean Bandit 03-19-2001, 06:37 AM I'll read it up too thanks for clearing up!:bandit: Adam 03-19-2001, 05:08 PM i just saw that bhp was base horspower TheMan5952 03-19-2001, 09:00 PM BHP is Brake Horsepower. I am reading a Automotive Engineering text book like thing for fun, (I'm 15, not old enough to be in College yet), They explain it all, it means Brake Horsepower. SHP, Shaft HorsePower. There measure how much HP is at the end of the Propeller shaft. FYI: 1 hp = about 750 watts. Porsche 03-20-2001, 06:06 PM How do they measure it then? I'm assuming it's not a a Dynometer. TheMan5952 03-21-2001, 01:32 AM Not sure how they measure it, Maybe the hook something on the shaft and that measure it. Not sure. Steve 03-22-2001, 05:48 PM Brake Horse power is the power rating at the wheels and shaft horse power is measured at the output shaft of an engine. Most people use brake horsepower for vehicles because it is easier to drive it on a dyno than to pull the engine and hook it up to a water brake. TheMan5952 03-22-2001, 07:33 PM Hey Steve, When I was reffering to shaft HP, I was talking about Helicopter Rotor Shafts. Steve 03-22-2001, 08:56 PM Yep, SHP could refer to the power turbine out put shaft of a helicopter or any turbine engine, or crankshaft of a recipricating engine. I guess you could use it to measure anything that produced torque. As far as I know the only difference in BHP and SHP is where it is measured. SHP is at the source, BHP is at the wheels. By the way I like your reference to helicopters. I'm an Instructor Pilot for the CH47D Chinook in the Army. My website has some pictures from Desert Storm, if you want to see some serious SHP (7500 SHP). TheMan5952 03-23-2001, 12:25 AM sweet, that sounds awesome. They also have Net BHP and Gross BHP. Difference is at Wheels and at flywheel with all accesories (Alternator, Power steering pump, water pump, A/C). Porsche 03-25-2001, 06:04 PM Your're a Chinook training pilot? That is so cool. Does it make the 7500 SHP from one engine or the two combined? What's the maximum load you've ever lifted? I heard the "Lumberjack" converted models can lift13T. Steve 03-25-2001, 09:42 PM Thanks, It is alot of fun. The Chinook makes 7500 SHP with two engines. Actually the two engines can make over 10,000 SHP on a standard day at sea level, but that is limited by transmission torque limit of 7500. The extra power capability comes in handy at higher altitudes when the air is thinner and the engine power is less. I have lifted around 24,000 lbs but I didn't have much fuel on board. Normally full of gas it will lift 20,000 easy. Max gross is 50,000. The logging version is stipped down so they can lift more of a load. I think thier max gross may be higher also. If your interested I have some Chinook pictures on my web site.:wave: texan 03-26-2001, 03:57 AM this is an excerpt from an older article of mine on compression science, it should answer the static vs. dynamic compression ratio question. "Static compression ratio: the total amount of volume in the chamber at BDC vs. the amount at TDC (that's Bottom Dead Center and Top Dead Center, respectively). Now I gave some simplified versions of this in the last discussion to aid in explaining what I was talking about, but here's the actual formula... Static Compression Ratio = (S+C)/ C Where S= total swept volume and C= chamber volume, and... Swept volume= (x² × pi) × stroke Where X= radius of the bore (bore/2), and... Chamber volume= cylinder head volume + gasket volume + piston volume + crevice volume Now it's not important to be able to actually calculate these numbers yourself, as either Honda Motor Co. or your piston provider will have already done this. What's important is to note that static compression ratio is entirely mechanical, being based solely on swept volume and chamber volume. Meaning that the amount of air flowing into the engine has no effect on static compression ratio. Now, for a quick explanation of VE... VE (Volumetric Efficiency) is an expression of how much air is actually flowing into an engine vs. how much total air it can displace, and is always expressed as a percentage. For example, a Honda B16A motor has a displacement of 1.6L, so if you had 1.6L of air flowing into and out-of the motor at every 2 RPM (being that these motors are 4 strokes, it takes 2 revolutions of the crank to completely pump air in and out), you would have a VE of 100%. It's VERY important to know here that VE varies with RPM, as the engine's efficiency at flowing air is continually changing. In fact, VE is one of the most important factors to engine performance. The entire torque curve can be indirectly expressed as a result of VE. The only reasons why it isn't directly proportional to VE are the air/fuel ratio, ignition timing, overall mixture homogeny (uniformity) and frictional losses. Other than that, the VE percentage is basically what makes the torque curve rise and fall on any dyno chart. In fact, it's basically a given to state that maximum torque output of any engine also comes at maximum VE. So OK, as VE rises and drops in an engine, so does power output. But what does that mean? Well that question leads us to a concept called dynamic compression ratio, which is in truth, probably the most basic of all engine parameters. Th dynamic compression ratio is, simply... Dynamic CR= static CR x VE To illustrate, if you had a static CR of 10:1, and had a VE of 90%, you would have... Dynamic CR= 10 x .9 (90% stated in decimal form), or 9:1 dynamic CR" Now obviously the explanation as to what this means to performance and combustion dynamics has been left out, but this should give you all the math and background needed to understand each term. Hope this helps, peace. JD@af 03-27-2001, 08:10 PM I was honestly going to research this tonight and post the differences. Guess I'll take this as another lesson on why not to put things off for too long. Thanks for the assist, Tex! Bean Bandit 03-28-2001, 12:25 PM good one Tex:bandit: Moppie 07-04-2001, 02:12 AM Shp is a measure of the hp at the output shaft that the proppeler or rotors are attached to, not the output shaft of the engine(s). This way it takes into account having two engine hooked together (as in the chinhook) or changes in torque through a gearbox, (most small planes use some kind of reduction drive). Its usefull for knowing what size and pitch of propellar/rotor can be used, and how well it will preform. Automotive Network, Inc., Copyright ©2012
