gaskets?GtRider 10-01-2001, 02:57 AM need a desperate tuneup on my p10! wanted to know 1. do i need to use a gasket sealant when replacing the valve cover gasket? 2.how bout when i change why transmission pan gasket? 3. or the oil pan gasket? P10DET 10-01-2001, 06:55 AM Originally posted by GtRider 1. do i need to use a gasket sealant when replacing the valve cover gasket? Yes. Just two very short beads of RTV at the hump over the distributor. The FSM shows it very clearly. Originally posted by GtRider 2.how bout when i change why transmission pan gasket? 3. or the oil pan gasket? I have no idea about the auto tranny. The oil pan doesn't have a traditional gasket. It uses only RTV silicone to seal it. Be sure you clean off all the old RTV and don't mar the sealing surfaces when you scrape off the old goo. Automotive Network, Inc., Copyright ©2012
