HorsepowerMilliardo 01-02-2003, 01:54 PM Does anyone know how many horsepower the 1993 Civic ESi has? And how much is added when you put in 9.5mm spark cables, air filter and intake, take out the cat, and a large exhaust? q2ar13 01-05-2003, 05:20 AM Not to be too rude or anything but first of all spark plug wires aern't giong to give you any hp just keep you engine sparking a tiny, tiny bit better at higher RPM's. Second I hope you don't have pipes any bigger than 2 1/4 becuase it'll only hurt you unless you've got a turbo. Third of all even if you get a top of the line intake and catback and take off the cat you aren't getting more than 15 hp and that's all high RPM hp. besides hp isn't important at all it just who's the fastest when you pull up to the light and It doesn't seem it'll be you. Milliardo 01-05-2003, 08:49 AM Originally posted by q2ar13 besides hp isn't important at all it just who's the fastest when you pull up to the light and It doesn't seem it'll be you. Not to be rude either, but I hope I don't run into you. Erhm, hp isn't important? Eh...anyway, let's see how much hp I have added when I put my set-up. My friend's estimate is around 10. Not too much, but then again it made a lot of difference. And yeah, I am not through yet with my mod. civicHBsi91 01-05-2003, 12:24 PM whats the esi's baseline power? CivicSpoon 01-05-2003, 05:30 PM Not to sound completely ignorant but what is a ESi? Is it an Ex with an Si motor or something or a totally different model? gunnmen01 01-05-2003, 05:39 PM there is no ESI the ex was a 2 or a 4 door, the SI was a hatchback....either way the ex/si motor was the D16Z6....rated at 125 hp at the crank. Spark plug wires will help it run better but not add any power unless you run an aftermarket ignition. Intake and filter will add a little bit of power. Taking out the cat. wont serve any purpose except to turn on the check engine light. However the larger exhaust will help some and with the right muffler will sound pretty good... gunnmen01 civicHBsi91 01-05-2003, 05:51 PM obviously hes overseas so there probably is an esi model....i have no clue though Milliardo 01-05-2003, 06:12 PM Originally posted by gunnmen01 there is no ESI the ex was a 2 or a 4 door, the SI was a hatchback....either way the ex/si motor was the D16Z6....rated at 125 hp at the crank. Spark plug wires will help it run better but not add any power unless you run an aftermarket ignition. Intake and filter will add a little bit of power. Taking out the cat. wont serve any purpose except to turn on the check engine light. However the larger exhaust will help some and with the right muffler will sound pretty good... gunnmen01 ESi was available here in the Philippines from 1992 to 1994 or such, until the next generation Civic came out. I am not sure if the model came out in Japan, though I would think it did if there's one here. Obviously there's also an ESi in Malaysia, so I think the ESi is only an Asian model. The cat was replaced by something my friend called a powerflow--essentially a cylindrical object that has the length of a cat. He claimed it helps the flow of exhaust more freely, as the name implied. And no, the check engine light doesn't stay on without the cat in mine, maybe because of the powerflow. What I am worried is if it would pass emissions test, though. But that won't come util 9 months later. I am not sure if having larger spark plug wires doesn't add power; I have noticed considerable, and consistent, gains with the change in both spark plugs and wires. Obviously it's not just the filter and intake, as I had those before the wires and plugs. An example of a Civic ESi: http://www.surbo.net/SMSA_240302/. It's the blue one. That one's in Malysia. Here's also a pic of my Civic, with hood open. gunnmen01 01-05-2003, 06:19 PM Down from the distributor and over on the block there is a small flat surface that will have a # on it it will read either D16Z6 0r D15XX something.... if its the D16 its 125 HP, if its the D15 its like 105 hp...hope this helps... gunmen01 Milliardo 01-05-2003, 06:23 PM Originally posted by gunnmen01 Down from the distributor and over on the block there is a small flat surface that will have a # on it it will read either D16Z6 0r D15XX something.... if its the D16 its 125 HP, if its the D15 its like 105 hp...hope this helps... gunmen01 Most likely it's the D16, but I'll check. Couldn't just be 105hp, as even as stock it could hold out well on its own against other Civics, as well as other cars. civicHBsi91 01-05-2003, 06:27 PM it could be 105hp lx's have something like 92hp or something and i hold my own against alot of cars with that......top end is crazy on that for a stock 93 lx Milliardo 01-05-2003, 06:29 PM Funny, it's not a D16 or even D15. It's an RH16. I am not sure if that engine is available in the U.S. Below it are 7 numbers, if it helps. But yeah, I took a good look at it and it's RH16. civicHBsi91 01-05-2003, 06:33 PM did you look at the block? or where did you get this info? and if its really a rh16 then its a 1.6L Milliardo 01-05-2003, 06:36 PM Originally posted by civicHBsi91 did you look at the block? or where did you get this info? and if its really a rh16 then its a 1.6L Yup, looked at the spot that gunmen01 specified. And yes, the ESi is 1.6L (failed to mention that one). Automotive Network, Inc., Copyright ©2012
