Annoying Seat Belt Chime!
floridafree
12-30-2002, 02:50 PM
Help!,
I've 1994 Jeep Grand Cherokee replaced chime module as I broke it trying to remove it. Repl. chime drove from Fla to Texas and back no chime thought it was fixed now after driving about 200 yards it gives a steady chime is there a time relay? I figure a wire is grounding where it ain't suppose to problem is I have no wiring diagram Ieven got desperate cut the balck wire to the module at the module killed the chime but also killed my power door locks! I have respliced thewire where can I cut this damn thing and stillkeep my door locks Igive a shit less if I have seat belt warning we wear them all the time don't needa reminder any help will be greatly appreciated.
dallywags
06-29-2005, 08:39 PM
Help!,
HI, I'M HAVING THE SAME PROBLEM WITH MY JEEP. SAME MODEL. I TRIED REPLACING THE POWER CONTROL MODULE, BUT IT DIDN'T FIX IT. BEFORE I TAKE IT INTO THE DEALER AND SPEND SOME BUCKS, I'M HOPING YOU MIGHT HAVE FOUND THE ROOT OF THE PROBLEM?
I HEARD IT MIGHT BE A FUSE, BUT I DON'T HAVE FUSE DIAGRAM - OR OWNERS MANUAL.
I HOPE YOU MANAGED TO FIX YOUR TRUCK!
THANKS FOR ANY ADVICE YOU CAN PASS ON.
Stick89
07-05-2005, 06:11 AM
On the pre 90s'there is a CHIME MODULE.This is what is "binging".On th 89'you can remove the CHIME MODULE,it is located in the lower left side of the fuse panel.
dallywags
07-05-2005, 10:41 AM
Unfortunately, this only opens up a whole new group of problems, including no power locks, interior lights or any accessories working.
REmoving the chimer only disrupts the circuit. And I already replaced the box too, so it wasn't the problem, anyway.
Thanks, though. I appreciate the suggestion!
