3.8 L Coolant leak
Bumpa2
12-29-2002, 06:17 PM
My 95 Bonne with 3.8L uncharged engine (90 k miles) is consuming coolant. No external leaks (hoses, clamps, core plugs, water pump, radiator, heater or overflow tank). Coolant side pressure checked hot & cold OK. Coolant sniffed for exhaust; none detected. Here is the crux: the exhaust pipe drips GREEN LIQUID. Engine runs fine (for now). Any comments would be appreciated.
Thanks
Bumpa2
Shortbus
12-30-2002, 10:37 AM
It's not going in the oil pan is it? Thats a weird one. Is your coolant the orange crap (dexcool) or green. How much coolant is it using?
Bumpa2
12-30-2002, 07:57 PM
I've used the green stuff since mile 1. No coolant in oil (drained and settled for separation). I read about several cases of coolant leaking into the intake via the upper intake manifold (black fiber or plastic) but I didn't think coolant actually circulated above the lower aluminum manifold.
Shortbus
12-31-2002, 09:08 AM
Yeah we do keep those upper intakes in stock, cause they crack a lot.
I am pretty sure it has to do with coolant leaking. That would be a good place to look.
Scott 02
01-29-2003, 11:18 AM
How much are those by the way?
Shortbus
01-29-2003, 11:28 AM
The pn is 17113136 and they list at 295.00
If you buy em right on the internet you can get them for 200.
Scott 02
01-29-2003, 11:46 AM
Sound good.
firehawkman
01-27-2004, 08:03 PM
i have 2 of those intakes came off a 98 bonneville not sure of the interchange on them if you can use them ill deal with ya need to get them outta my garage
IT247365
10-17-2011, 10:18 AM
I solved this problem. Check out http://dailytweak.wordpress.com/2011/08/22/3-8l-coolant-leak/
maxwedge
10-17-2011, 12:36 PM
Please check the dates first ,this is a 7 year thread and the solutions are well known.
