Vibration Question (2000 Maxima 5spd)
4 MAX FUN
12-28-2002, 11:32 AM
For the last couple of months I’ve picked up on a light, high frequency vibration in my 2000 Maxima SE. The car is mostly stock. I have two sets of aftermarket wheels, professionally balanced – one set of 16-inch rims, and one set of 17’s. The vibration is unchanged with either set installed. It feels more like a “motor thing” then an unbalanced tire.
The vibration is very light, but noticeable from just off idle all the way up. You can feel it through the floor, the steering wheel, and the gearshift. The motor feels strong, but I’m still suspicious of perhaps a need for a valve adjustment (car has 40k miles), or maybe low compression in one cylinder. I had a mechanic pronounce the motor mounts ok. Perhaps half shaft joints? Where should I look, and how should I troubleshoot to find a fix? It’s the kind of thing that you hate to turn a shop mechanic loose on ($$).
Oh, the car is used for autocross and track days. It seems like the vibration started after the last autocross of the season (won novice class!).
-b.
ivymike1031
12-29-2002, 04:39 PM
does the vibration change frequency w/ motor rpm, or w/ tire rpm?
