grounding wires?Darkwing 12-27-2002, 01:50 PM I got some driving lights, and to set it up, I need to ground 4 wires. Some of the spots are close quarters, so I was wondering 2 things: 1) can I ground more than one wire to the same spot? 2) can I ground the wire some other way than using a screw? Like superglue or something? Sounds pretty novice, I'm sure but I don't want to mess these up. Thanks :) kicker1_solo 12-27-2002, 02:01 PM You can ground more than one wire to the same spot, and super glue won't hold it. :D Darkwing 12-27-2002, 05:22 PM thanks, you know of anything that will hold it? RoBoDEATH 12-28-2002, 09:03 PM screws, just use them under something where they wont be visible, run wire from then and ground it somewhere else Duatone 12-29-2002, 06:50 AM thanks, you know of anything that will hold it? Duct Tape. A.K.A. "Cowboy Chrome" If you cant Duc' it, fuck it. Also, make sure your grounding to a bare piece of metal. its not hard, if you have to, drill a small hole somewhere in your engine bay and use self-tapping screws, but im sure there are a couple random nuts you can tap the wires into. Darkwing 12-29-2002, 06:10 PM hey thanks guys. I took robo's idea and spliced more wire onto it and extended it to a place I could drill a hole ito with those selftapping screws. All works now thanks again :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
