60 K Check up and service
Dondo
12-26-2002, 05:11 PM
Could someone tell me what is involved in a 60K service ?? Or tell me where I could go on the web to read what is involved in such a service ??
A web site or something,,, does anyone know,,,, please help !!
Dondo:confused:
bruno4
01-16-2003, 11:05 PM
It will vary upon which engine you have, either the Vulcan or Duratec, It also depends on the type of driving you do, such as Highway or Town. why not call your local dealer and ask, there is no obligation to take it there.
Hope this helps
Ian
Yamahasho
02-04-2003, 10:36 AM
The 60k is a tune up for the SHO. It requires adjusting the valve lash and changing the timing belt. Many people replace much more so they will not have to tear into the motor for awhile.
fordman123
02-05-2003, 12:43 PM
Services that I would recommend would be:
Tranny Flush and filter change
Oil Change
Coolant Flush
Clean Throttle Body
Clean Fuel Injectors
PCV Valve
Fuel Filter
Brake inspection
Hope this is what you were inquiring about
Yamahasho
02-05-2003, 02:04 PM
Oil Change
Coolant Flush
Clean Throttle Body
PCV Valve
Fuel Filter
Brake inspection
And most defenately the timing belt:jumpie:
7string
09-06-2003, 12:46 AM
change the engine
Alex_Perry
09-10-2003, 12:29 AM
the timing belt is only for the SHO. the same goes for a 60K. its a SHO procedure. all other taurus engines use a timing chain.
