non-vtec to vteccvcracerhond 12-25-2002, 12:49 PM is it possible to put a zc head on a d series engine? i have a dohc zc head non vtec and i was wondering could i put type r cams on it and is it possible to make it a vtec? hondacivic4drlx 12-25-2002, 01:18 PM i dont think so becuase the vtec distrubutor is different then the non vtec one. i dont think the parts will fit on it becase the ears on the distributors dont line up. i recently swaped a d15b in my hatch and wanted to see if i could use the distributor off my old engine and it didnt fit. but i know you could put the head on there but no vtec, and plus where the soleniod go? and the pressure switch?:rolleyes: :rolleyes: :silly2: :silly2: :silly2: :silly2: :silly2: 91civicDXdude 01-06-2003, 11:41 AM a DOHC d series head will not fit onto a SOHC d series block without extensive machining. you cannot make a non vtec engine vtec by adding different cams. you have to have the vtec selenoid and the vtec mechanisms in the head. If you really want to go VTEC, get a d16z6 or d16y8 head and mount it on your block. as far as the distributor goes, you can modify the distributor to fit so you can still adjust ignition timing. Automotive Network, Inc., Copyright ©2012
