2002Ram 1500 wiring diagram?bdutton 12-21-2002, 02:53 PM Anybody have a wiring diagram for the 2002 Dodge RAM 1500 Quad? Lambie 07-19-2003, 10:55 PM I also need a wiring diagram for my 2002 Ram 1500. Did you ever get one? I am trying to install a remote keyless entry system and am having problems. Any assistance you (or anyone else) can offer would be greatly appreciated. bdutton 07-22-2003, 06:10 PM Originally posted by Lambie I also need a wiring diagram for my 2002 Ram 1500. Did you ever get one? I am trying to install a remote keyless entry system and am having problems. Any assistance you (or anyone else) can offer would be greatly appreciated. Nada. Nuthin. Zilch. Best of luck. Bill. bsbrits 09-12-2003, 11:17 AM Without amp: Memory (+12v Constant) Red/White Ignition (+12v Switched) Red Ground (-) Black or Braided Silver Wire Illumination Orange Dimmer (none) Power Antenna Yellow S p e a k e r s Right Front (+) Violet Right Front (-) Blue/Red Left Front (+) Green Left Front (-) Brown/Red Right Rear (+) Blue/White Right Rear (-) Blue/Red Left Rear (+) Brown/Yellow Left Rear (-) Brown/Red With Amp: No the wires in and out of the amp are different. Wire colors for the Premium system are as follows: Radio : Left Front (-) BR/RD, (+) DG Right Front (-) DB/RD, (+) VT Left Rear (-) BR/LB, (+) BR/YL Right Rear (-)DB/OR,(+)DB/WT All into the Amp. From the Amp which is behind the glove Box : Right Dash (-)OR/RD, (+) OR/BK Left Dash (-) YL/RD, (+) YL/BK Center Dash (Right (+)) OR/BK, (Left (-)) YL/RD Front Left Door(-) LG/DG,(+)LG/RD Front Right Dooor(-)LB/BK,(+)LB/RD Rear Left Door(-)WT/BK,(+)WT/RD Rear Right Door(-)TN/BK,(+)TN/VT The center speaker is split between the right and left speaker All this is from the service manual. bdutton 09-14-2003, 12:23 PM Thats great info. But do you or anyone else know the wiring for the door locks? I need to wire a keyless entry system to the door locks. The door lock panel on the drivers side is an enclosed circuit board and I am unable to isolate the wires leading to it as those that lock/unlock the doors. bsbrits 09-18-2003, 10:18 AM Try this. For 2002 quad cab You can also go to www.the12volt.com Alarm/Remote Start Info: Battery (+): -----------RED + IGNITION SWITCH HARNESS Starter 1: ------------- YEL + IGNITION SWITCH HARNESS Ignition 1A(+): -------DRK. BLU IGNITION SWITCH HARNESS Ignition 2A(+): -------RED + IGNITION SWITCH HARNESS Ignition 2B(+): ------- RED/WHT + IGNITION SWITCH HARNESS Accessory (+): ------- BLK/WHT + IGNITION SWITCH HARNESS Tach Sensor: --------- RED/BLK OR BLK/GRY AT COIL ON DRV.SIDE OF ENGINE Key Sensor: -----------BLU (-) IGNITION SWITCH HARNESS Neutral Safety: ------ BLK/WHT (-) IGNITION SWITCH HARNESS Brake: -----------------WHT/TAN + AT BRAKE SWITCH Reverse Lights: ------VIO/BLK (+) 16 PIN GRY CONN DRIVERS DASH Window Roll-Up: --- LF: LT.BLU RF: --------------------- BRN/WHT Window Roll-Down: LF:WHT RF: --------------------- VIO/WHT Door Trigger: -------- BRN DRIVERS B PILLAR Parking Lights: ----- VIO/YEL - RELAY ISOLATE GROUND W/320 OHM RESISTOR Headlights: ---------- PURPLE/YELLOW 680 OHM RESISTOR,SAME AS PARK LIGHTS Pwr Door Lock: ----- WHITE/GREEN - DR. KICK USE 680 OR 815 OHM RESISTOR Pwr Door Unlock: ---WHITE/GREEN - DR. KICK PANEL USE 320 OHM RESISTOR Horn: -------------------BLK/RED (-) 74 PIN CONN BEHIND DR. DASH OR COLUMN Factory Disarm: ----- LT.GRN/ORG(-) DR. KICK GROUND PULSE THROUGH 1500 OHM DR. Mtr Unlck: ------PNK/BLK + LEFT KICK PANEL DR. Motor lock: -----ORG/BLK + LEFT KICK PANEL Factory Alarm: ------ LT.GRN/ORG(-) DR. KICK GROUND PULSE THROUGH 760 OHM Passenger Unlck: --- PNK/VIO + LEFT KICK PANEL DOOR TRIGGER ALSO AT TIMER MOD USE TAN FOR DR. DOOR AND BLK/LT.BLU FOR PASS DOOR DIODE ISOLATE FACT ARM/DISARM WIRE WILL LOCK DOOR / 2 PULSE FOR UNLOCK Astrotram 01-16-2009, 11:06 PM Download PDF Dodge Ram 2005 Service Manual | PDFTown.com (http://pdftown.com/PDF-Dodge-Ram-2005-Service-Manual.html) Automotive Network, Inc., Copyright ©2012
