95 Caprice Classic Enginedourthing 12-16-2002, 08:46 PM I just replaced the ignition module and fuel filter on my 95 Caprice Classic 4.3L V8 engine. the car start great and runs great, however, when the car reached its operating temperature, the engine will dies and shutdown without any symptoms. Upon restarting, the engine will buck, grumble, hesitate, limp and dies again. After letting the engine cool for so many hours, everthing will be fine, but repeat the same cycle again when its warm up. Can this condition cause by a faulty temperature sensor? any suggestions? jayrw123 05-22-2003, 07:48 AM Hello, It sounds like you have a bad coil. Once the coil heats up the, the heat resistance in the coil is causing it to short out. You will find your coil on the drivers side of the engine, in front of the drivers side head. I would try this, very inexpensive fix. The coil runs about 25 bucks at autozone. Try replacing this, I had the same problem with by 95 caprice Lt-1. This fixed the problem. You sould be good to go. Good luck! Jay. Automotive Network, Inc., Copyright ©2012
