Air Bag Code "45"Jbsb1657 12-16-2002, 10:21 AM Can anyone help? I'm giving my mother in-law my 95 Taurus and the air bag light flashes "45". Anyone know what it stands for? Thank You! projects 12-25-2002, 08:14 PM That should be: Center Radiator Primary Sensor Not Mounted Properly to Vechicle. Jbsb1657 01-11-2003, 10:13 PM Thank You! 2000 ford taurs 04-19-2011, 05:15 PM hi! may i ask ... would the "45" code be the same for a 2000 taurus? inafogg 04-19-2011, 06:11 PM hi! may i ask ... would the "45" code be the same for a 2000 taurus? no,the 1995 uses OBD1 system 1996 - current uses OBD 2 YOU WILL NEED A SCANNER TO PULL CODES way2old 04-19-2011, 07:53 PM On your 2000, the code 45 translates to: Passenger Side Impact Severity Sensor Communications Fault I would look at the sensor wiring and connections. Automotive Network, Inc., Copyright ©2012
