2001 taurus blank key programinggazoo 12-15-2002, 09:33 PM Can anyone tell me if I can program a blank key? fordman123 02-05-2003, 12:47 PM Only if you have the 2 original keys already programmed to it. Or a scan tool with the necessary software. Only options for a PATS Key Good Luck garrett1025 02-24-2004, 07:28 AM Only if you have the 2 original keys already programmed to it. Ihave 2 keys programmed to it... I don't however have the owners manual.... Any help would be great Thanks 02duratec 02-25-2004, 02:31 PM it tells you exactly how to do it in the owners manual as long as you have one key programmed medicTA 02-25-2004, 10:36 PM From the 2001 manual: Programming spare keys: A maximum of eight keys can be coded to your vehicle. Only SecuriLocky keys can be used. To program a coded key yourself, you will need two previously programmed coded keys (keys that already operate your vehicle’s engine) and the new unprogrammed key(s) readily accessible for timely implementation of each step in the procedure. If two previously programmed coded keys are not available, you must bring your vehicle to your dealership to have the spare coded key(s) programmed. Please read and understand the entire procedure before you begin. 1. Insert the first previously programmed coded key into the ignition and turn the ignition from 3 (OFF) to 4 (ON) (maintain ignition in 4 (ON) for at least one second). 2. Turn ignition to 3 (OFF) then 2 (LOCK) and remove the first coded key from the ignition. 3. Within ten seconds of removing the first coded key, insert the second previously programmed coded key into the ignition and turn the ignition from 3 (OFF) to 4 (ON) (maintain ignition in 4 (ON) for at least one second but no more than ten seconds). 4. Turn the ignition to 3 (OFF) then 2 (LOCK) and remove the second coded key from the ignition. 5. Within 20 seconds of removing the second coded key, insert the new unprogrammed key (new key/valet key) into the ignition and turn the ignition from 3 (OFF) to 4 (ON) (maintain ignition in 4 (ON) for at least one second). This step will program your new key to a coded key. 6. To program additional new unprogrammed key(s), repeat this procedure from step 1. If successful, the new coded key(s) will start the vehicle’s engine and the theft indicator will illuminate for three seconds and then go out. If not successful, the new coded key(s) will not start the vehicle’s engine and the theft indicator will flash on and off and you may repeat steps 1 through 6. If failure repeats, bring your vehicle to your dealership to have the new spare key(s) programmed. mkent45 07-30-2004, 04:01 PM Where can you buy these PATS keys? My dealer wants 28 bucks each. drdisque 07-30-2004, 09:51 PM there's always alot of them listed on ebay. Automotive Network, Inc., Copyright ©2012
