an easy beginer questionMurray 09-26-2001, 02:14 PM All I was wondering was how to bridge an amp, and what does this do? I have a 360 w 2 channel Boss amp and 2 10" MTX subs. (Channels are how many pairs of speaker outputs right?) Is it possible to bridge this amp? Any help would be great. :ylsuper <center><img src="http://www.angelfire.com/sk/SaSk/images/34bigfront.jpg"></center> DVSNCYNIKL 09-26-2001, 02:18 PM Bridging is when you combine channels. So if you have a 4 channel amp, you can bridge two of them to the others and change it to a 2 channel. Now from experience, this will give you significant boost. But over the long wrong, would be not quite useful. I know people who do this are in competitions where this would be very useful. I personally have had a few systems in my cars and have done this in two of them. But like I said, in the end, I ended up changing this set up and kept them as is. I could see you bridging now also if you had a multiple amp setup. But then again, it comes down to what you do in the end. Murray 09-27-2001, 01:24 PM Channels are how many pairs of speaker outputs right? http://www.geocities.com/TimesSquare/Lair/4595/frontexcel.jpg DVSNCYNIKL 09-27-2001, 01:26 PM Right. wellsit 12-20-2001, 04:16 PM Not all amps are bridgable. If yours is though you should also know that hooking up you speakers in parallel will give you a power boost by decreasing the impedance. ex: Two 4 ohm speakers hooked up in parallell will look like one 2 ohm speaker to am amp, thus increasing the power to the speakers. One drawback to this is that it makes your amp run hotter, especially if it is not 2 ohm stable. If your amp gets too hot it will turn off to protect itself from cooking. cody911911 05-29-2004, 11:51 PM There really wouldn't be any reasom to bridge your amp because most likely it is meant to be bridged for a 4 ohm load which in most cases is meant for a single 4 ohm speaker.. You would most likely be better off by running each speaker on its own channel....as for bridging the amp all you need to do is hook up a positive in one chanel and the negative in the other....most bridgeable amps will have a diagram showing what ports to use to be in bridged mode. Automotive Network, Inc., Copyright ©2012
