Brakes
96 Jetta GL / ABA Engine.
I have no power to the LF brakes. I put the car on jack stands and let the wheels spin in first gear. I had my buddy hold down the brake(which goes to the floor) and only the RF brake grabs, while the LF spins faster. I thought it might be a booster issue because If you pump the brake pedal while stopping you get a somewhat more firm pedal. Could this be a failed master cylinder? I removed the grommet on booster because it had a small leak when I moved the vacuum hose side to side. It looked pretty bad so I'm going by the dealership to pick it up. I've also just changed the front brake pads and rotors. Although this didn't fix anything. Any help will be appreciated.
