please my 98 caravan wont start
mathew23
12-15-2007, 11:32 PM
my 98 caravan wont run it turns over but wont fire checked fuel filter but wasnt it it ran for a few minuts after but now it wont fire any suggestions on what could be the problem
RIP
12-15-2007, 11:41 PM
Turn the key to "on" and listen for a humm at the fuel tank. Silence? Smack the tank with a mallet. Still silent? Check for power and a ground at the fuel pump connector. Got both? Change the fuel pump.
mathew23
12-16-2007, 04:35 PM
fuel pupm works no spark wont fire though
RIP
12-16-2007, 09:19 PM
No spark? PCM commands coil to deliver voltage to plug wires. Coil would be my first choice. Inspect the connection at the coil from the PCM for corrosion.
This explains both distributorless ignition systems (2.4, 3.3, 3.8 ltr engines) and those with a distributor (3.0 ltr). Click the headings at the right.
http://www.autozone.com/az/cds/en_us/0900823d/80/1a/3b/d0/0900823d801a3bd0/repairInfoPages.htm
HeadlessHorseman1
12-16-2007, 10:58 PM
I had a bad cam sensor which caused the same problem. Is your vehicle throwing any error codes?
copierfixerguy
12-29-2007, 03:26 PM
Matt....I was having problems with my van too.... found out that the computer was wacked out. It was adding too much gas causing it to flood. Check out my thread. Chrysler repair guy gave me some great tips.
97K15004WD
01-11-2008, 06:08 AM
Can you post a link to your thread here?
tempfixit
01-11-2008, 07:50 AM
I believe this is the thread copierfixerguy is referring too:
http://www.automotiveforums.com/vbulletin/showthread.php?t=772384
Good Luck
copierfixerguy
01-11-2008, 11:32 PM
thanks tempfixit......I forgot to give the link.
